Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 09-19-2017, 21:02   #1 (permalink)
Member: 706822
Thanks Meter: 647
emmc update b503 EMMC pro king box done.Medusa pro problem ;)
Welcome to Medusa Pro Software version 1.4.4.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: FT SCR2000 0
Reader #2: FT SCR2000 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Samsung eMMC 000000
Page size : 512 B
Block size : 512 B
Block count : 33554432
CID Info
CID : 1501003030303030305620110726589D
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 000000
Product revision : 5.6
Product serial number : (hex) 20110726
Manufacturing date : 05/2021
CSD Info
CSD : 902701320F5903FFF6DBFFEF8A404023
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Erase block size : 512 Kbytes
Boot1 size : 512 Kbytes
Boot2 size : 512 Kbytes
RPMB size : 128 Kbytes
Partition config : 00000000
Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 4026531840 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_54_15.bin.
Connect successful.
SW: 1.4.4; FW: 1.22.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_54_48.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_55_13.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_56_11.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_56_16.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_56_33.bin.
Connect successful.
Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KMVTU000LM-B503/KMVTU000LM-B503_FW.bin...Done.
Finalizing...Done.
Changing CID to 15010056545530304DF780F6213A2123.
Write CID succesfully completed.
Disconnected.
EMMC writing firmware done.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_57_05.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_57_20.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_57_44.bin.
Connect successful.
Finalizing...Done.
Write CID error.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_09_2017_22_58_39.bin.
Connect successful.
Disconnected.
eMMC PRO
eMMC Pro - eMMC Programmer Version V1.10
FIRMWARE(0x4D41494E) version:2017052915210004
SN:580676E30FF35F8F
eMMC Pro is Ready ..
Connect a Device and Click "Detect"
CID:0x15010030 0x30303030 0x300C2013 0x01281062
Manufacturer ID:0x15
Device/BGA:1 (removable:1 BGA:2 POP:3)
OEM/Application ID:0x00
Product name:0x303030303030 (000000)
Product revision:0x0C
Product serial number:0x20130128
Manufacturing date:0x10
CRC7 checksum:0x62
CSD:0xD0270132 0x0F5903FF 0xF6DBFFFF 0x8E40406C
CSD structure:0x3
System specification version:0x4
Data read access-time 1:0x27
Data read access-time 2:0x1
Max. bus clock frequency:0x32
Card command classes:0x0F5
Max. read data block length:0x9 (512)
Partial blocks for read allowed:0
Write block misalignment:0
Read block misalignment:0
DSR implemented:0
Device size:0xFFF
Min. read current @ VDD min:0x6
Max. read current @ VDD min:0x6
Min. write current @ VDD min:0x6
Max. write current @ VDD min:0x6
Device size multiplier:0x7
Erase group size:0x1F
Erase group size multiplier:0x1F
Write protect group size:0x1F
Write protect group enable:1
Manufacturer default ECC:0
Write speed factor:3
Max. write data block length:0x9
Partial blocks for write allowed:0
Content protection application:0
File format group(R/W):0
Copy flag (OTP)(R/W):1
Permanent write protection(R/W):0
Temporary write protection(R/W):0
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x36
Not used, always ’1’:0
RCA:0x00000000
EXT_CSD information parsing:
FFU features:0x00
BOOT_SIZE_MULTI[226]:0x10
HC_ERASE_GRP_SIZE[224]:0x01
ERASE_TIMEOUT_MULT[223]:0x01
HC_WP_GRP_SIZE[221]:0x50
SEC_COUNT(EXT_CSD[215:212]:0x01D5A000)
CARD_TYPE(EXT_CSD[196]):0x07
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x06
PARTITION_CONFIG[179]:0x00
BOOT_CONFIG_PROT[178]:0x00
BOOT_BUS_CONDITIONS[177]:0x00
ERASE_GROUP_DEF[175]:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
RPMB_SIZE_MULT[168]:0x01
WR_REL_SET[167]:0x1F
WR_REL_PARAM[166]:0x05
SANITIZE_START[165]:0x00
BKOPS_START[164]:0x00
BKOPS_EN[163]:0x00
RST_n_FUNCTION[162]:0x00
HPI_MGMT[161]:0x00
PARTITIONING_SUPPORT[160]:0x07
MAX_ENH_SIZE_MULT[159:157]:0x0000BB
PARTITIONS_ATTRIBUTE[156]:0x00
PARTITION_SETTING_COMPLETED[155]:0x00
GP_SIZE_MULT[154:143]:0x000000000000000000000000
ENH_SIZE_MULT[142:140]:0x000000
ENH_START_ADDR[139:136]:0x00000000
SEC_BAD_BLK_MGMNT[134]:0x00
PRODUCTION_STATE_AWARENESS[133]:0x00
TCASE_SUPPORT[132]:0x00
PERIODIC_WAKEUP[131]:0x00
PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01
NATIVE_SECTOR_SIZE[63]:0x00
USE_NATIVE_SECTOR[62]:0x00
DATA_SECTOR_SIZE[61]:0x00
INI_TIMEOUT_EMU[60]:0x00
Class6_CTRL[59]:0x00
DYNCAP_NEEDED[58]:0x00
EXCEPTION_EVENTS_CTRL[57:56]:0x00
EXCEPTION_EVENTS_STATUS[55:54]:0x00
EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00
CONTEXT_CONF[51:37]:0x000000000000000000000000000000
PACKED_COMMAND_STATUS[36]:0x00
PACKED_FAILURE_INDEX[35]:0x00
POWER_OFF_NOTIFICATION[34]:0x00
CACHE_CTRL[33]:0x00
FLUSH_CACHE[32]:0x00
MODE_CONFIG[30]:0x00
MODE_OPERATION_CODES[29]:0x00
FFU_STATUS[26]:0x00
PRE_LOADING_DATA_SIZE[25:22]:0x00000000
MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00
PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00
SECURE_REMOVAL_TYPE[16]:0x00
Basic Information:
Extended CSD revision: Revision 1.6 (eMMC v4.5)
User Data Area Size: 15028MB(0x3AB400000)
Boot Partition Size: 2048KB
RPMB Size: 128KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Erase group size: 512KB
Begin to program firmware of KMVTU000LM-B503
Begin to read firmware
Firmware is downloaded correctly
Begin to program cid
Program CID finished.
eMMC PRO
SN:580676E30FF35F8F
CID:0x15010056 0x54553030 0x4DFC3D39 0x868641FA
Product name:0x56545530304D (VTU00M)
Product revision:0xFC
Product serial number:0x3D398686
Manufacturing date:0x41
CRC7 checksum:0xFA
CSD structure:0x3
DSR implemented:0
Device size:0xFFF
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x36
RCA:0x00000000
FFU features:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
BKOPS_EN[163]:0x00
HPI_MGMT[161]:0x00
CACHE_CTRL[33]:0x00
FFU_STATUS[26]:0x00
Basic Information:
RPMB Size: 128KB
Old 09-21-2017, 08:38   #2 (permalink)
Member: 642767
Thanks Meter: 27
each tool is complementary
Page generated in 0.27590 seconds with 8 queries
