Success Reports [ eMMC Pro ] Please post your success reports here Best Regards F4T0N |
LG L FINO AKA LG D295 THE 1ST FULL EMMC SUPPORTED LG L FINO aka LG D295 Problem: boot img cant go to download mode FIX BY EMMC PRO https://scontent.fmnl4-6.fna.fbcdn.n...01&oe=58C8F0D0 https://scontent.fmnl4-6.fna.fbcdn.n...4b&oe=5898CCCA https://scontent.fmnl4-6.fna.fbcdn.n...16&oe=5892E240 https://scontent.fmnl4-6.fna.fbcdn.n...02&oe=58D4E67C thanks to Ozgur Oz for full support to fix this problem. Ron2pet for box and 150ohm |
oppor831k oppo r831k connection ok now waiting for downloading for dump too slow speed in server eMMC PRO eMMC Pro - eMMC Programmer Version V1.08 FIRMWARE(0x4D41494E) version:2016122615000000 SN:6B04395BB3DCCCEC eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x3E4871FA 0x04050DA1 0x34473164 0x90014A48 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483447316404 (H4G1d) Product revision:0x05 Product serial number:0x0DA13E48 Manufacturing date:0x71 CRC7 checksum:0xFA CSD:0x8A4040D2 0xFFFFFFEF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00748000) CARD_TYPE(EXT_CSD[196]):0x17 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x06 PARTITION_CONFIG[179]:0x48 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0000E9 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: Revision 1.6 (eMMC v4.5) User Data Area Size: 3728MB(0xE9000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
contact me dump file |
1 Attachment(s) FIRST_IN_THE_FORUM_LG_G4_H810_FLASH_FULL_DUMP Quote:
TIME TAKEN 3 Hrs 25 Minutes & 38 seconds. BR |
oppo r831k hang on logo fixed with emmc-pro Regards |
eMMC Pro good work... isp+...DAT 1.2.3... eMMc Pro box Support ISP Universal Device Programmer 100%...OK but eMMc Booster Tool only SD-card reader... GL827L IC ...handles the single USB 2.0 port and SD-card reader work ... images pcb...... https://plus.google.com/105724940295...ts/SWVNQNfX34z |
i need dump for A11w? |
Thanx EMMC PRO BOX TEAM FOR YOUR FULL SUPPORT User Data Area Size: 15028MB(0x3AB400000) Boot Partition Size: 2048KB RPMB Size: 128KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Address : 0x0000000000000000 - 0x0000000000FFFFFF Reading Started... Reading Done ! File Saved C:\Users\user\Desktop\1\Dump.bin Area is changed to BOOT1(size:0x00200000) Area is changed to User(size:0x3AB400000) Address : 0x0000000000400000 - 0x00000000013FFFFF Reading Started... Reading Done ! File Saved C:\Users\user\Desktop\1\Dump 2 Area is changed to BOOT2(size:0x00200000) Area is changed to User(size:0x3AB400000) Address : 0x0000000000400000 - 0x00000000013FFFFF Reading Started... Reading Done ! |
