03-17-2018, 22:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2001 Location: Idrija
Member: 3496 Status: Offline Thanks Meter: 8 | A500F Detect eMMC failed(60)) help Resoldered wires, pull up resistor. I got the connnection but in the middle of reading storp afterwords no connection and error 60. Any idea how to fix? Regards! Leo |
03-27-2018, 15:53 | #2 (permalink) |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Error 60 case mostly connection problem or required pull-up . pull-up scenario for this device is CMD - 160 ohm to VCC and D0 - 160 ohm to VCC but in your case you said it was working so could be connection and i suggest you to resolder your pinouts and try again and especially CMD , D0 , CLK Connection is very sensitive for this model . Best Regards F4T0N |
03-28-2018, 06:22 | #3 (permalink) |
Member: 3496 Status: Offline Thanks Meter: 8 | Hi, thanks for the reply. Will retray it. Same thing is now happening with N7000, treid pull up resistor same result, without pull up resistor same result, resoldered wires same result Will try your suggestions on A500F and post the results on forum. Regards! Leo |
04-13-2018, 18:09 | #4 (permalink) |
Member: 3496 Status: Offline Thanks Meter: 8 | Hi, tried all you suggestions but no luck. Always get 60 error eaven if i connect external supply. Treid with N7000 and same result. I need a solution so that i can use the box. Regards! Leo |
