07-25-2017, 22:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | Vodafone Smart 7 World First mathew_di ;) EMMC PRO ;) eMMC Pro - eMMC Programmer Version V1.09 FIRMWARE(0x4D41494E) version:2017052915210004 SN:580676E30FF35F8F eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x90014A48 0x38473165 0x05075122 0x8C2D33CC Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847316505 (H8G1e) Product revision:0x07 Product serial number:0x51228C2D Manufacturing date:0x33 CRC7 checksum:0xCC CSD:0xD0270132 0x0F5903FF 0xFFFFFFEF 0x8A4040D2 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x38 User area enabled for boot BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Area is changed to EXT_CSD(size:0x200) Address : 0x0000000000000000 - 0x00000000000001FF Reading Started... Reading Done ! File Saved F:\VODAFONE SMART 7 QUALCOM 8909 EMMC PRO MATHEW_Dİ\EXTCSD.bin Area is changed to BOOT1(size:0x00400000) Address : 0x0000000000000000 - 0x00000000003FFFFF Reading Started... Reading Done ! File Saved F:\VODAFONE SMART 7 QUALCOM 8909 EMMC PRO MATHEW_Dİ\BOOT1.bin Area is changed to BOOT2(size:0x00400000) Address : 0x0000000000000000 - 0x00000000003FFFFF Reading Started... Reading Done ! File Saved F:\VODAFONE SMART 7 QUALCOM 8909 EMMC PRO MATHEW_Dİ\BOOT2.bin CID:0x90014A48 0x38473165 0x05075122 0x8C2D33CC Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847316505 (H8G1e) Product revision:0x07 Product serial number:0x51228C2D Manufacturing date:0x33 CRC7 checksum:0xCC CSD:0xD0270132 0x0F5903FF 0xFFFFFFEF 0x8A4040D2 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
