Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 12-28-2017, 14:40   #1 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
j200f dead but detect how to revive guide me
hello team first time i connect any set with emmc now what i need to revive
company-samsung
model- j200f
condition-dead but when connect to computer its connect and ask driver sec s5pc210 test b\d
successfully connect with box now what i do
www.emmc-pro.com
eMMC Pro - eMMC Programmer Version V1.10
FIRMWARE(0x4D41494E) version:2017052915210004
SN:77017EB1F633C606
eMMC Pro is Ready ..
Connect a Device and Click "Detect"
CID:0x15010046 0x4E31324D 0x42009922 0xDCC892BA
  Manufacturer ID:0x15
  Device/BGA:1 (removable:1 BGA:2 POP:3)
  OEM/Application ID:0x00
  Product name:0x464E31324D42 (FN12MB)
  Product revision:0x00
  Product serial number:0x9922DCC8
  Manufacturing date:0x92
  CRC7 checksum:0xBA
CSD:0xD0270132 0x0F5903FF 0xF6DBFFEF 0x8E40400C
  CSD structure:0x3
  System specification version:0x4
  Data read access-time 1:0x27
  Data read access-time 2:0x1
  Max. bus clock frequency:0x32
  Card command classes:0x0F5
  Max. read data block length:0x9 (512)
  Partial blocks for read allowed:0
  Write block misalignment:0
  Read block misalignment:0
  DSR implemented:0
  Device size:0xFFF
  Min. read current @ VDD min:0x6
  Max. read current @ VDD min:0x6
  Min. write current @ VDD min:0x6
  Max. write current @ VDD min:0x6
  Device size multiplier:0x7
  Erase group size:0x1F
  Erase group size multiplier:0x1F
  Write protect group size:0xF
  Write protect group enable:1
  Manufacturer default ECC:0
  Write speed factor:3
  Max. write data block length:0x9
  Partial blocks for write allowed:0
  Content protection application:0
  File format group(R/W):0
  Copy flag (OTP)(R/W):1
  Permanent write protection(R/W):0
  Temporary write protection(R/W):0
  File format(R/W):0
  ECC code(R/W):0
  CRC(R/W):0x6
  Not used, always ’1’:0
RCA:0x00000000
EXT_CSD information parsing:
FFU features:0x00
BOOT_SIZE_MULTI[226]:0x20
HC_ERASE_GRP_SIZE[224]:0x01
ERASE_TIMEOUT_MULT[223]:0x01
HC_WP_GRP_SIZE[221]:0x10
SEC_COUNT(EXT_CSD[215:212]:0x00E90000)
CARD_TYPE(EXT_CSD[196]):0x57
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x07
PARTITION_CONFIG[179]:0x00
 Device not boot enabled (default)
BOOT_CONFIG_PROT[178]:0x00
BOOT_BUS_CONDITIONS[177]:0x01
ERASE_GROUP_DEF[175]:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
RPMB_SIZE_MULT[168]:0x04
WR_REL_SET[167]:0x1F
WR_REL_PARAM[166]:0x14
SANITIZE_START[165]:0x00
BKOPS_START[164]:0x00
BKOPS_EN[163]:0x00
RST_n_FUNCTION[162]:0x00
HPI_MGMT[161]:0x00
PARTITIONING_SUPPORT[160]:0x07
MAX_ENH_SIZE_MULT[159:157]:0x0001D2
PARTITIONS_ATTRIBUTE[156]:0x00
PARTITION_SETTING_COMPLETED[155]:0x00
GP_SIZE_MULT[154:143]:0x000000000000000000000000
ENH_SIZE_MULT[142:140]:0x000000
ENH_START_ADDR[139:136]:0x00000000
SEC_BAD_BLK_MGMNT[134]:0x00
PRODUCTION_STATE_AWARENESS[133]:0x00
TCASE_SUPPORT[132]:0x00
PERIODIC_WAKEUP[131]:0x34
PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01
NATIVE_SECTOR_SIZE[63]:0x00
USE_NATIVE_SECTOR[62]:0x00
DATA_SECTOR_SIZE[61]:0x00
INI_TIMEOUT_EMU[60]:0x00
Class6_CTRL[59]:0x00
DYNCAP_NEEDED[58]:0x00
EXCEPTION_EVENTS_CTRL[57:56]:0x00
EXCEPTION_EVENTS_STATUS[55:54]:0x00
EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00
CONTEXT_CONF[51:37]:0x000000000000000000000000000000
PACKED_COMMAND_STATUS[36]:0x00
PACKED_FAILURE_INDEX[35]:0x00
POWER_OFF_NOTIFICATION[34]:0x00
CACHE_CTRL[33]:0x00
FLUSH_CACHE[32]:0x00
MODE_CONFIG[30]:0x00
MODE_OPERATION_CODES[29]:0x00
FFU_STATUS[26]:0x00
PRE_LOADING_DATA_SIZE[25:22]:0x00000000
MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00
PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00
SECURE_REMOVAL_TYPE[16]:0x09
Basic Information:
Extended CSD revision:
User Data Area Size: 7456MB(0x1D2000000)
Boot Partition Size: 4096KB
RPMB Size: 512KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Erase group size: 512KB
when i go to support always showing-This serial number is expired
Old 01-03-2018, 11:35   #2 (permalink)
Member: 2547620
Thanks Meter: 3,431
Succesful connection proceed writing dump
Best Regards
F4T0N
Old 01-06-2018, 05:05   #3 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
where can i find this dump and how to write
Old 01-06-2018, 05:21   #4 (permalink)
Member: 513210
Thanks Meter: 110
Go to support area and download the full dump.
about asking expired serial make sure that no other dongle or box that connected in your pc or laptop...
Old 01-07-2018, 05:55   #5 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
j200f no dump awailable on support now where or how can i can i revive this set and what should bacup before writing dump
Page generated in 0.14110 seconds with 8 queries
