Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > Gmunlocker(powered by GSMideazone)
Old 07-22-2017, 07:57   #46 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Originally Posted by GMC View Post
how to resolve this problem:
Process completed with ERRORS.
***Wait for reboot to confirm the SIMLock status.[Reasons]
1. ChallengeData is missing in server response
***Hints***
1. Check your Internet connection.
2. If problem persist, contact the admin.
Updating devices list. Done!
SIM Unlock Failed
*HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure.
Connecting to device...
Application info
Version 4.3
Copyright © 2016
Created by dk
Enjoy it ;-)
Loading device info (Client Version 4.3). Done!
***Device Info
Model: Nokia Lumia 820 (RM-825)
Sw Version: 3051.50009.1424.0015
Product Code: 059Q9Q0
IMEI: 354105052759080
NETWORK LOCK: ACTIVE
possible solution
1.disable windows auto upodate
2.disable firewall
3.disable antivirous
4.use windows 7 pc
if still fail
come whatsapp =- +8801911954639
Old 07-24-2017, 11:22   #47 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
After unlock with lumia unlocker now phone dosent connect with any flasher like ATF, Best, Recovery tool.Whats to do?I think driver is overhidden now but how to enable it?I did uninstall APP driver from software but still dosent work.
Old 07-25-2017, 09:59   #48 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
you need contact support in whatsapp
Old 08-15-2017, 17:36   #49 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,331
i alredy downloaded from some supports few eno files, rename and put in correct folders but nothign happen when press again unlock/download.
why should i do?
The Following 2 Users Say Thank You to Boshko_Alfa For This Useful Post:
Old 08-15-2017, 20:18   #50 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
why should i do?
come whatsapp
+8801911954639
i will check by remote
The Following 2 Users Say Thank You to ..::Gsmideazone::.. For This Useful Post:
Old 08-24-2017, 01:13   #51 (permalink)
Member: 1691127
Thanks Meter: 5
hi friend, please, help me i cant unlock lumia 620
log:
Hints
1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed.
2. Need view phone info? Connect it and press 'Get Info' button.
3. Select as many rows as you want and press Ctrl+C to copy it content.
4. More than one phone connected? Connect the device to unlock.
5. Use reload button for rescan the connected devices.
***Device Info
Model: Lumia 640 LTE (RM-1073)
Sw Version: 02177.00000.15184.36016
Product Code: 059X0B8
IMEI: 3578160604xxxxx
1. Invalid Authentication Token
***Hints***
2. Check the authentication token.
3. Check the client app's version.
SIM Unlock Failed
Connecting to server...
***Hints***
***Device Info
SIM Unlock Failed
i reflash file .xml and dont can unlock
whatsapp +51987592872
Old 08-28-2017, 12:42   #52 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
***Device Info
Model: Nokia Lumia 520 (RM-914)
Sw Version: 3058.50000.1425.0010
Product Code: 059S2W9
IMEI: 359205051310763
***Device Info
1. Unable to connect to the remote server
***Hints***
SIM Unlock Failed
how to solve this problem
thx
Old 08-28-2017, 16:16   #53 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
Testing connection with Unlock Server ... FAIL
Old 08-28-2017, 19:21   #54 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
all lumia unlock server temporary down
pls wait some time
Old 08-29-2017, 10:59   #55 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
server is ok
unlock ok
thx
The Following User Says Thank You to patric For This Useful Post:
Old 09-06-2017, 15:13   #56 (permalink)
Member: 38138
Thanks Meter: 4
Does the handset need to have a non-network product code?
Hello,
Not having much luck with trying to unlock a Lumia 640 from EE. The handset is flashed with non-branded software but I do not know how to change the product code to match the firmware. Is this why the software is not unlocking the handset:
1. No phone found in Test Mode
SIM Unlock Failed
SIM Unlock Failed
***Device Info
Model: Lumia 640 LTE (RM-1072)
Sw Version: 02177.00000.15184.36003
Product Code: 059X1Q3
IMEI: 35185807xxxxxxxx
Grateful for any advice
Many thanks
The Following User Says Thank You to soudies For This Useful Post:
Old 09-06-2017, 15:54   #57 (permalink)
Member: 38138
Thanks Meter: 4
Changed pc to a windows 10 and that did the job.
Old 09-12-2017, 14:29   #58 (permalink)
Member: 1957238
Thanks Meter: 80
@@@@@@..::Gsmideazone::..
i have a lumia 1520 rm 937 v02061.00066.14253.4004 imei 35834205145235 its now 4 days trying to set it in testmode for but when finished downloading testmode pack software says download error crc32. i tried several time reflashing the and repeat operation with no luck. with other models i managed to do it in few clicks. please help me cause now i am nowhere, should my money go for nothing since the code can only be used on one device. i bought the credit/authentication code from active unlocker, i tried to contact the active unlocker team but they are to slow to respond .
what i just need is the good testmode package for the above device causee i even tried manual download and rename the file but the software stuck at setting testmode untill device reboot due to timeout. your help will be appreciated.
Old 09-12-2017, 20:25   #59 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
whatsapp me
+8801911954639
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post:
Old 10-02-2017, 16:15   #60 (permalink)
Member: 352564
Sonork: 100.1592785
Thanks Meter: 23
unable to connect remote server ---
i am trying to unlock lumia 635 always this error
Page generated in 0.24861 seconds with 9 queries
