Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 07-23-2020, 14:53   #1 (permalink)
Member: 1136376
Thanks Meter: 2
SHP smart heating platform error b.01
Hello
I have SHP smart heating platform, and if I don't use it for some time when trying to use it it doesn't work,
on the screen it only shows b.01, I have tried to update it using its original usb cable that brought the equipment and other usb cables, connecting to usb 3.0 and 3.1 ports on three different computers and it only emits several beeps and does not update, I have tested the versions available in the software (SHP V1 Normal, SHP V2 test and SHP V6).
I have tried again, allowing 24 hours to pass
What should I do?
Thank you.
Old 07-23-2020, 15:10   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
i reply your issue by email , please check !
The USB port voltage too low, need > 4.9V
Old 07-23-2020, 15:52   #3 (permalink)
Member: 1136376
Thanks Meter: 2
thanks for answering
but the usb ports are ok i have already tried it on other desktop computers and it is not updated
also send an email to support
Old 07-23-2020, 16:00   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
Yes, i read your email , as i check the voltage of your usb is 0.00, did you saw that ?
Please check
Br.,
Old 07-23-2020, 16:48   #5 (permalink)
Member: 1136376
Thanks Meter: 2
no the voltage is not in 0.00, when the equipment is in that mode b.01 the computer program does not recognize it but the usb still have 4.9v, this error stops when I stop using the equipment and if the computer shuts down with the SHO connected from usb port
I could not know why this error happens
Old 07-23-2020, 16:54   #6 (permalink)
Member: 1136376
Thanks Meter: 2
In the two images that I send you by email, the SHP is on and in the computer application it says in purple SHUTDOWN
Old 07-23-2020, 17:22   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
Please send update logs to support email , i will check
Old 07-23-2020, 17:56   #8 (permalink)
Member: 1136376
Thanks Meter: 2
I sent you the last two log files, yesterday and today, by mail
Old 07-24-2020, 06:50   #9 (permalink)
Member: 79315
Thanks Meter: 6,024
Will check today , dont worry
Old 07-24-2020, 15:33   #10 (permalink)
Member: 1136376
Thanks Meter: 2
Hello gsmdenis
Today I tried several times to update the SHP, and finally it worked
thanks for the support
very thankful
The Following User Says Thank You to wcbs For This Useful Post:
Page generated in 0.19802 seconds with 8 queries
