Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
03-25-2022, 21:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 54 | Redmi note 11 problem with WiFi & network Did anybody see such problem on a new device? MIUI has been full of bugs for quite some time but this is really bad. Any help would be appreciated, even a testpoint photo; Thank you. |
The Following 2 Users Say Thank You to Zaki Bouzidson For This Useful Post: |
03-25-2022, 23:35 | #2 (permalink) |
Member: 2287326 Status: Offline Thanks Meter: 54 | Was on 13.0.5 and upgraded to 13.0.6 using recovery mode (MiFlash Pro), WiFi is good now but still no cellular network (both IMEIs are ok) if I try to call I get this message: "Turn off Airplane mode to make a call" although Airplane mode is already off. |
06-16-2022, 13:51 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | HAVE SAME SITUATION HERE (phone new, no wifi, no cell) BUT AS I KNOW FOR NOW THE PHONE IS NOT SUPPORTED FOR FLASHING ON ANY BOX !! |
The Following User Says Thank You to temp_temp For This Useful Post: |
06-26-2022, 22:34 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | I'm starting to think that this Redmi Note 11 is going to be as problematic as the poco M3. I have one here that does not connect but is directly recognizing in EDL mode when I connect. I have two others that when starting, it locks the functions and restarts by itself. I still haven't found any box that does the reinstallation of his firmware. |
The Following User Says Thank You to celltellpb For This Useful Post: |
07-02-2022, 10:16 | #6 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | as always, new Qualcomm phone need a lot of research to find or patch the loader in order to be able to service phone we have to wait until dev's find solution |
08-22-2022, 11:19 | #10 (permalink) |
Freak Poster Join Date: May 2010 Location: pakistan
Member: 1297994 Status: Offline Sonork: 100.1614596 Thanks Meter: 35 | Mi note 11 wifi issue [Same Prolem here anyone have soluiton please share here and my phone has been reset=Zaki Bouzidson;14536311]A customer came with a note 11 [2201117TG] (product name "spes") which doesn't have network connection at all. And it hangs everytime I try to turn on WiFi, the phone is brand new and only have been used for about a month, I don't know if it's a software (maybe damaged persist partition or a similar one) or hardware issue, I can't even install a zip update file offline. Did anybody see such problem on a new device? MIUI has been full of bugs for quite some time but this is really bad. Same Prolem here anyone have soluiton please share here and my phone has been reset Any help would be appreciated, even a testpoint photo; Thank you.[/QUOTE] |
08-25-2022, 23:43 | #11 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Bro, this is hardware problem Just check SDR/RF when sdr ic damage, then network/ wifi baseband modem properly not work |
