Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi > Xiaomi Hardware Repair
Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help
Old 03-25-2022, 21:36   #1 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 54
Redmi note 11 problem with WiFi & network
A customer came with a note 11 [2201117TG] (product name "spes") which doesn't have network connection at all. And it hangs everytime I try to turn on WiFi, the phone is brand new and only have been used for about a month, I don't know if it's a software (maybe damaged persist partition or a similar one) or hardware issue, I can't even install a zip update file offline.
Did anybody see such problem on a new device? MIUI has been full of bugs for quite some time but this is really bad.
Any help would be appreciated, even a testpoint photo; Thank you.
The Following 2 Users Say Thank You to Zaki Bouzidson For This Useful Post:
Old 03-25-2022, 23:35   #2 (permalink)
Member: 2287326
Thanks Meter: 54
Was on 13.0.5 and upgraded to 13.0.6 using recovery mode (MiFlash Pro), WiFi is good now but still no cellular network (both IMEIs are ok) if I try to call I get this message: "Turn off Airplane mode to make a call" although Airplane mode is already off.
Old 06-02-2022, 19:44   #3 (permalink)
Member: 177620
you need to flash whole rom not recovery but edl
Old 06-16-2022, 13:51   #4 (permalink)
Member: 570252
Thanks Meter: 207
HAVE SAME SITUATION HERE (phone new, no wifi, no cell)
BUT AS I KNOW FOR NOW THE PHONE IS NOT SUPPORTED FOR FLASHING ON ANY BOX !!
The Following User Says Thank You to temp_temp For This Useful Post:
Old 06-26-2022, 22:34   #5 (permalink)
Member: 689942
Thanks Meter: 312
I'm starting to think that this Redmi Note 11 is going to be as problematic as the poco M3. I have one here that does not connect but is directly recognizing in EDL mode when I connect. I have two others that when starting, it locks the functions and restarts by itself. I still haven't found any box that does the reinstallation of his firmware.
The Following User Says Thank You to celltellpb For This Useful Post:
Old 07-02-2022, 10:16   #6 (permalink)
Member: 570252
Thanks Meter: 207
as always, new Qualcomm phone need a lot of research to find or patch the loader in order to be able to service phone
we have to wait until dev's find solution
Old 07-04-2022, 20:28   #7 (permalink)
Member: 2287326
Thanks Meter: 54
Didn’t “xiaomi pro tool” work for you?
Old 07-05-2022, 17:39   #8 (permalink)
Member: 570252
Thanks Meter: 207
Unhappy
talk with them on support & not supported by fire tool only official service cost 40$
Old 07-25-2022, 15:31   #9 (permalink)
Member: 570252
Thanks Meter: 207
any news about this phone ?
Old 08-22-2022, 11:19   #10 (permalink)
moon_sns's Avatar
Member: 1297994
Sonork: 100.1614596
Thanks Meter: 35
Post Mi note 11 wifi issue
[Same Prolem here anyone have soluiton please share here and my phone has been reset=Zaki Bouzidson;14536311]A customer came with a note 11 [2201117TG] (product name "spes") which doesn't have network connection at all. And it hangs everytime I try to turn on WiFi, the phone is brand new and only have been used for about a month, I don't know if it's a software (maybe damaged persist partition or a similar one) or hardware issue, I can't even install a zip update file offline.
Any help would be appreciated, even a testpoint photo; Thank you.[/QUOTE]
Old 08-25-2022, 23:43   #11 (permalink)
helpful-man's Avatar
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
Bro, this is hardware problem
Just check SDR/RF
when sdr ic damage, then network/ wifi baseband modem properly not work
Old 10-03-2022, 09:13   #12 (permalink)
Member: 2993893
Thanks Meter: 4
I also had problems with the wi fi connection
Old 10-03-2022, 09:26   #13 (permalink)
Member: 2993893
Thanks Meter: 4
Old 10-19-2022, 09:46   #14 (permalink)
Member: 2746928
What's New about this phone ?
Page generated in 0.23580 seconds with 8 queries
