QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
01-20-2005, 16:35 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Up North
Member: 14934 Status: Offline Thanks Meter: 79 | Samsung Z107 UNLOCK SOLLUTION FREE simple use. com connector and short tx and rx pin 2-3 on the (com) use samsung original usb cable PCB157ULE 1. plug in phone install usb drivers 2. open QIWS_V1.16(Service)_041011.exe 3. plug in com adapter (tx and rx shorted) 4. check if program finds samung modem. (if not found, go back to 1) 5. press ok 6. press unlock, (if you get usb error try to go to 4 and change the usb comport manualy to something else) 7. if phone unlocked insert a gsm card (if you have problem with network just change it manualy to gsm instead of automatic) links for program and cable information can be found here... http://forum.gsmhosting.com/vbb/showthread.php?t=173873 i have nothin more to say... exept.... why but agere attack when they probably use same sollution themself for z105 and z107 |
01-22-2005, 12:28 | #4 (permalink) |
Junior Member Join Date: Jul 2004
Member: 71908 Status: Offline Thanks Meter: 0 | i have here a problem i try it with a z100 datacable connected pin 2-3 in female DB9 and to the green cable in the samung usb cable with a switch samsung modem is in port 14 Serial com...Good WAIT! Detect USB Port Sucess: direct USB Port... Searching Samsung Modem... Usb Port Open Sucess Lock Read Fail any ideas where the failure can be? thx |
01-27-2005, 22:18 | #11 (permalink) |
Junior Member Join Date: Jan 2005 Age: 44
Member: 109058 Status: Offline Thanks Meter: 0 | No need to make the cable. Just use the original USB cale, and then make an adapter that short out pins 2 and 3 on your COM1. (You can just use a piece of wire to do this) The software only checks the carrier on the COM port, and then it uses the USB serial port to do the unlock. |
01-28-2005, 01:10 | #12 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Minsk Russia
Member: 5569 Status: Offline Thanks Meter: 10 | all work @forhike all work .....i tried with green wire more but not and i tried your solution ALL WORK and resolve phone freeze BR Own but winimei z105 work with Z110? |
01-30-2005, 16:13 | #15 (permalink) | |
Member: 14934 Status: Offline Thanks Meter: 79 | Quote:
does it exist in europe? or is it asia modell ? | |
i ned Samsung Z105 UNLOCK SOLLUTION FREE | touta1 | QUALCOMM Models (3G) | 0 | 09-18-2008 17:48 |
Help Samsung Z107 Unlock | blueaurabd | QUALCOMM Models (3G) | 5 | 06-29-2007 12:35 |
Samsung Z107 Unlocking | afrodizzy | FuriouS II | 7 | 11-18-2005 20:51 |
Samsung E800 Unlock Code, Free | gaz_0001 | SYSOL Platform | 10 | 05-04-2005 21:31 |
samsung d500 unlocking for free | ronnyj1 | SWIFT Platform | 4 | 12-18-2004 10:33 |
