HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
10-21-2004, 14:47 | #4 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Lithuania
Member: 6744 Status: Offline Thanks Meter: 0 | check that Press power off switch and after that press reset button ( it's hidden little hole for needle) .Or in reverse way . This will reset your PDA to default , and will clear ALL DATA . For user manual check : http://www.qtek2020.ch/SupportEN.htm |
10-21-2004, 17:18 | #6 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Italy Age: 48
Member: 7019 Status: Offline Thanks Meter: 0 | These are the instructions to unlock your QTEK 2020 phone - Please follow the instructions carefully. 1. Download the QTEK 2020 unlock software from http://mrfax.altervista.org/1/downlo...nlock-v2.2.exe 2. Tranfer xda2unlock-v2.2.exe to any directory on your QTEK 2020 using the 'Explore' funtion of ActiveSync Software. (ActiveSync Software can be downloaded from: http://mrfax.altervista.org/1/downlo...20/MSASYNC.EXE 3. Run xda2unlock-v2.2.exe from your QTEK 2020 and you will be prompted to ask if u realy want to unlcok it select yes and it should be done Best regards MRFAX |
10-31-2004, 20:42 | #8 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
Worked very well Thanks | |
11-03-2004, 20:13 | #9 (permalink) | |
Freak Poster Join Date: Jun 2001 Location: ROMANIA Age: 47
Member: 5021 Status: Offline Thanks Meter: 3 | Quote:
Big big thanks for solution Best regards, katagsm | |
LCD for Qtek 2020 or Tmobile MDA ll | Rhamses | Various | 0 | 02-20-2005 13:53 |
need update for QTEK 2020 | garfild | HTC & PDA WM( With Touchscreen) | 0 | 02-17-2005 11:26 |
qtek 2020 | andorrani1 | HTC & PDA WM( With Touchscreen) | 0 | 11-13-2004 19:02 |
Qtek 2020 display? | et.com | Wanted Products | 0 | 09-17-2004 15:51 |
Qtek 2020 flashing interrupted | 45PR1 | HTC & PDA WM( With Touchscreen) | 5 | 07-24-2004 15:35 |
