Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
08-31-2008, 15:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BD/Italy
Member: 324042 Status: Offline Sonork: 100.1578276 Thanks Meter: 3,504 | ..::A Simple and Easy Way to TRANSLATE a (sis) Application::.. This is a tut about you can translate .sis Progs into other Languages. So at first what youll need: ~ SISWare (im using 4.6 Beta, but newer should also work) ~ RESEdit Ok, we will begin: 1. Step: Run SISWare -> click File -> Open Session. Open the prog you want to translate. For exmple translating to german. 2. Step: Click Tools -> Extract SIS File -> Extract All Files. 3. Step: Open RESEdit. Open the resource file of your prog. Example: I extracted the file "RotateMe.v1.5.Repacked.SAMET04106.unsig ned.SI S". So the containce of the sis is under My Documents\bin\RotateMe.v1.5.Repacked.SAM ET04106.un signed. Mostly youll find the .rsc file under *myprog*\resource\apps\ 4. Step: Simple translate the phrases to your wanted language. 5. Step Click File -> Save as... and replace the origin. Now go back to SISWare and change to Edit Mode. (Mode -> Edit Mode). Click the green arrow to build the new .sis File. Done! You translated the prog! ~ SISWare .............................. mehedi.h.j [email protected] SignSIS-GUI_v1.1.rar [RS LINK] OR |
The Following 5 Users Say Thank You to mehedi.h.j For This Useful Post: |
08-31-2008, 20:14 | #3 (permalink) |
Junior Member Join Date: Dec 2007
Member: 659240 Status: Offline Thanks Meter: 3 | i always wanted smsbox for lovers full version... it is availabale in russian.. i want to translate in in english... is it possible...???? |
The Following User Says Thank You to roopam005 For This Useful Post: |
FREE and EASY ways to unlock NEC 525 515 | NECUnlocker | NEC | 29 | 10-26-2011 17:19 |
correct and easy way to reball BGA ic | shahidsattar | Nokia Hardware & Hardware Repair | 9 | 02-20-2009 10:58 |
..::A Simple and Easy Way to TRANSLATE a (sis) Application::.. | mehedi.h.j | Java, iOS, Android, Symbian development | 0 | 08-31-2008 15:52 |
newest and easy way to done test point for db2020 | morteza-icu | Sony Ericsson | 13 | 08-26-2008 22:57 |
Simple and easy way to flash phones through testpoints without soldering iron ..:) | ezzis | Infinity-Box | 20 | 04-25-2008 08:36 |
