07-25-2008, 06:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: CrYstAL CloCk Age: 37
Member: 541092 Status: Offline Thanks Meter: 59 | U700v Successfully Unlocked 1. press 9 + power on and connect fone to pc with usb cable 2.select U700 and flash ur fone with U700_Patch_IMEI_Unlock.qst 3.make sure u have tick on format ffs 4.after flash complete 5. USe Rj45 + Usb combo cable to do unlock Excellent UST-PRO2!>< |
The Following 6 Users Say Thank You to gsmtime For This Useful Post: |
08-28-2008, 09:38 | #2 (permalink) |
Freak Poster Join Date: Mar 2008 Location: In This Forum
Member: 724951 Status: Offline Thanks Meter: 37 | 1. press 9 + power on and connect fone to pc with usb cable 2.select U700 and flash ur fone with U700_Patch_IMEI_Unlock.qst 3.make sure u have tick on format ffs 4.after flash complete try to unlock 5. USe Rj45 + Usb combo cable to do unlock but problem that.... Reading data from box... Searching for UMTS phone on box port... Phone not found! Elapsed Time (00:10) |
08-30-2008, 23:28 | #5 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | Quote:
jep...it's important ! U can find in device manager,in modems,samsung cdma modem,and U must change it to be COM 1,it's best to be 1. and ,after flashing with usb cable,it's next thing important when use RJ45+USB cable,that usb part is conected on same usb port of pc where was been conected while flashing.Of course,rj45 is conected on UST. | |
09-26-2008, 05:57 | #12 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
change modem port no it should be lower them ustpro port no. attach as show in your post and do all feature. | |
10-01-2008, 10:51 | #15 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 942 | Plus check cable i occurr at prob with found phone same cable that i flash phone can't unlock phone other cable unlock ok Regards |
The Following User Says Thank You to Formingus For This Useful Post: |
u700v successfully unlocked by hwk | raoul plus | HWK | 3 | 09-03-2009 22:23 |
u700v successful unlock | multicom_fsdpk | NSPRO | 3 | 12-29-2008 09:10 |
u700v successfully downgraded to u700 then unlocked with ust-pro | dasuza | UST Pro II | 45 | 09-15-2008 23:15 |
Server is back success unlocking U700v | digit@ll | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 0 | 08-09-2008 17:52 |
