12-05-2004, 13:03 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 51
Member: 83306 Status: Offline Thanks Meter: 13 | sharp gx25 does anyone knows how to unlock gx25 , i tried with gx 15 soft. but it doesn´t work. the gx15 softwear opens but when i do "leer" it goes up to 50% and then says error , is there any trick to p+ut this soft. running ?? tkx to all group in advance |
12-05-2004, 14:00 | #2 (permalink) | |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Quote:
Regards GSM MIND STAND ALONE | |
12-05-2004, 15:52 | #3 (permalink) |
Member: 83306 Status: Offline Thanks Meter: 13 | tkx dude , but i dont have redbox , i´ve heard that guys from group manage to unlock there phones with softwear free , i agree with redbox, but i cant buy all boxes in mercat just because of few sharp or nec that need redbox. |
12-10-2004, 22:44 | #4 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
Othervice ..... bye Red Bx .... The best BOX !!!!! | |
12-23-2004, 09:01 | #5 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: Slovenia Age: 46
Member: 8478 Status: Offline Thanks Meter: 0 | Quote:
01-02-2005, 12:29 | #6 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Europe
Member: 69725 Status: Offline Thanks Meter: 36 | Quote:
It will be soon One screenshot for you... but this is now the old version http://www.gsm-si.net/SharpUnlocker.jpg Regards Gogy | |
03-19-2005, 14:24 | #8 (permalink) | |
Freak Poster Join Date: Nov 2001 Location: SENEGAL
Member: 7335 Status: Offline Thanks Meter: 1 | soft Quote:
[email protected] regards | |
03-24-2005, 05:06 | #10 (permalink) |
Junior Member Join Date: Sep 2004
Member: 84295 Status: Offline Thanks Meter: 0 | Unlock gx25 with cracked furious install gx25 modem drivers check which com port modem is using select phone model gx15 in furious select correct com port unlock phone screen goes black remove battery for a few seconds then replace screen turns white with xxxx on display -press 1 -press 99 -press TOP RIGHT BUTTON -press 3 (for unlocking) -press 1 (are you sure) -press TOP RIGHT BUTTON (you see .... _FORMAT after 3 sec) -press 3x TOP RIGHT BUTTON after finished unlocking and phone switch OFF switch back on unlocked works 100 percent just unlocked 2 gx25's |
03-24-2005, 18:30 | #13 (permalink) | |
Registered User Join Date: Mar 2004 Location: cairo - Egypt
Member: 59418 Status: Offline Thanks Meter: 6 | Quote:
tested by me Best regard ............ >>>>>>>>>>>>>>>>>> | |
06-27-2005, 14:01 | #14 (permalink) | |
Banned Join Date: May 2003 Location: Heavens
Member: 30124 Status: Offline Sonork: 100.1590000 Thanks Meter: 7,900 | Quote:
06-27-2005, 19:29 | #15 (permalink) |
Freak Poster Join Date: Jan 2005 Location: France
Member: 103520 Status: Offline Thanks Meter: 17 | yes tested today with furious OK just a tip battery must be full charged or you can't do it and phone stay with **** and wait full charged bat to continue. Tested as well today exactly the same procedure with a gx10 manualy put in Drag mod with 0, 3, top-right key and on together then 0,1,2,3 topright key. After use the same -press 1 -press 99 -press TOP RIGHT BUTTON -press 3 (for unlocking) -press 1 (are you sure) -press TOP RIGHT BUTTON (you see .... _FORMAT after 3 sec) -press 3x TOP RIGHT BUTTON after finished unlocking and phone switch OFF Very good to unlock phone without any material !! |
need to unlock sharp gx17 and sharp gx25 | lacasapc | Sharp | 10 | 02-05-2008 20:47 |
sharp gx25 sharp 903 | iamchinese | Sharp | 1 | 08-06-2006 23:30 |
Sharp GX25 | GoGy | FuriouS II | 7 | 12-28-2004 23:04 |
sharp gx25? | danilo_nop | Sharp | 12 | 12-21-2004 19:37 |
can furious unlock sharp gx25? | crysst | FuriouS II | 2 | 11-20-2004 22:24 |
