11-02-2007, 10:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 47
Member: 597666 Status: Offline Thanks Meter: 286 | Succesfull with Bluetooth 2.0 CECT LV-918 "Bad Software" problem plz download eeprom_file (2 file) from infinity support area root/flashfile/Chinesmiracle/MT6205-MT6227/repair_eeprom/ MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_02.B0E & MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_03.B0E dowmload firmwarefile from infinity support area root/flashfile/Chinesmiracle/MT6205-MT6227/noname/ MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar _w_eeprom.B0M first chinesmirecle tool speed set on 460800 write eeprom MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_03.B0E write firmwarefile MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar _w_eeprom.B0M try there & replay post |
The Following 6 Users Say Thank You to sagtel For This Useful Post: |
11-02-2007, 16:17 | #4 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: india ( Gujarat )
Member: 370998 Status: Offline Sonork: 100.1582579 Thanks Meter: 219 | Thanks........... Quote:
100% solution i have repaired 7 phone, i was waiting 4 this solution THANKS INFINITY GR8... CHANDRESH | |
The Following User Says Thank You to Chandreshswami For This Useful Post: |
11-02-2007, 20:27 | #5 (permalink) | |
Product Manager Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Thank you very much for good solution and tests ! We will add this solution in Infinity-Box documentation. | |
11-03-2007, 10:52 | #10 (permalink) | |
Freak Poster Join Date: Apr 2005
Member: 141269 Status: Offline Thanks Meter: 28 | Quote:
Regards, Deepssssss.!!!!!!! | |
11-03-2007, 19:41 | #11 (permalink) | |
No Life Poster Join Date: May 2007 Location: In Think
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | Quote:
11-04-2007, 03:43 | #12 (permalink) |
Freak Poster Join Date: Oct 2007 Location: country
Member: 621936 Status: Offline Thanks Meter: 42 | My respect to Mr. Sagtel for his good work ! p.s. Somebody (I don't tell this name but everybody already know this name) "borrow" this method and files and tried to become little bit more famous but it was bad method to become famous. bad "borrow" method is here, people must know "the hero": 1st this: http:///vbb/showpo...21&postcount=8 2nd this: http:///vbb/showthread.php?t=462786 |
11-06-2007, 09:40 | #14 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Tried This But Not Successful. With Above Method The Handset Starts But Without Any Display graphics(Only Light)....... The Handset Make is ZTC At Startup it Displays ZTC then "BAD Software" If We try to format it COM25 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6225:8A03]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 20 sec Remove/Install battery now ! Tried to write originial firmware with that EEprom, But In vain The Handset Remains in "BAD Software" Position. I Think i Need Correct Flash Files for this Handset(My handsets Brand is ZTC not CECT). |
11-06-2007, 09:59 | #15 (permalink) |
Member: 597666 Status: Offline Thanks Meter: 286 | @ shubhanshu_sh plz download ZTC originial flash firmware file same as your model (eeprom.B0M file) from infinity support area flash this file & other problem change speed one by one |
chines Bluetooth 2.0 after flash "BAD SOFTWARE" | sagtel | Infinity-Box | 2 | 10-27-2007 09:02 |
