11-02-2007, 23:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | PDA A818 can't read fullflash for send to support Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.62 S/N: 04F1:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6228, E02 Hardware version: MTK_HW Software version: V818_A.POWERTIP.TE.0 Software date: 2004.07.02 Barcode: MT012345678901234567 imei: 350818002497569 Finished, time used: 22 sec Power off phone now ! COM8 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 error: Wrong model selected, select model: Autodetect 6228 NAND Finished, time used: 8 sec Remove/Install battery now ! Device: Autodetect 6228 NAND COM8 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 460800 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN ver. sw2: V818_A.POWERTIP.TE.06205 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.27EADFDB.[V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN _D3C715D5].rpl New firmware detected: V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished file saved: backup_system_log_27EADFDB_V818_A_PCB04_GPRS_MT622 8_S02.POWERTIP_TE_06205.BIN_D3C715D5_20071102-225821.B4X.bin Finished, time used: 79 sec Remove/Install battery now ! COM8 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 460800 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN ver. sw2: V818_A.POWERTIP.TE.06205 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: identification data damaged, recalculation required identification detection finished error: unexpected answer: warning: probably errors exist during flash read operation Finished, time used: 181 sec Remove/Install battery now ! |
11-03-2007, 00:37 | #2 (permalink) |
Product Manager Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, pls, send backup_system_log_27EADFDB_V818_A_PCB04_GPRS_MT622 8_S02.POWERTIP_TE_06205.BIN_D3C715D5_20071102-225821.B4X.bin file to [email protected] firmware reading: pls try at 230400 or 115200. Also don't use cable basd on Prolific cable, use unibox or any FTDI-based cable. |
11-03-2007, 09:38 | #3 (permalink) | |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
Hi! I used unibox cable. I'll try lower speed and post the result. There are some fotos of this new chinese phone )) | |
The Following User Says Thank You to JC_BY For This Useful Post: |
11-03-2007, 16:51 | #4 (permalink) |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Well done! I've been waiting for 2 hours to backup full flash of the phone! ==== log opened: [03.11.2007 11:11:56] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.62 S/N: 04F1:010C Wait... Device: Autodetect 6205-6227 NOR Done Device: Autodetect 6228 NAND COM8 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 230400 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN ver. sw2: V818_A.POWERTIP.TE.06205 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.27EADFDB.[V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN _D3C715D5].rpl New firmware detected: V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished file saved: backup_nand_[V818_A_PCB04_GPRS_MT6228_S02.POWERTIP_TE_06205.BIN]_full_20071103-131359.B4M.bin file saved: backup_system_log_27EADFDB_V818_A_PCB04_GPRS_MT622 8_S02.POWERTIP_TE_06205.BIN_D3C715D5_20071103-131512.B4X.bin Finished, time used: 7364 sec Remove/Install battery now ! I've already sent you backup of full flash (link to rapidshare). So please, check e-mail. I need to reformat this phone as soon as it doesn't want to start up propely with simcard inside. Can I excute safe format procedure right now with CM 1.62? Or should I wait for next update and support this model by software? |
11-03-2007, 17:50 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | File received, thanks a lot ! Yes, you can make "safe format" right now and see results. Then we will see do we need to make something else or not. |
11-04-2007, 11:41 | #6 (permalink) | |
Hallo! Thanky very much for support! I downloaded latest CM 1.63 and safe formated the device. Now all ok! COM8 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: V818_A.POWERTIP.TE.06205 Version: MTK_HW detecting structure #2... done imei: 35081800249756 connection Ok building list... done items to clear: 200 warning: wrong packet cs 191 of 200 items cleared building list... done 9 items remains Finished, time used: 102 sec Remove/Install battery now ! | |
01-11-2008, 14:35 | #9 (permalink) | |
Junior Member Join Date: Jan 2008
Member: 673497 Status: Offline Thanks Meter: 0 | A818 Pda Hi! How to do the formatting of A818 PDA with this? Quote:
01-12-2008, 22:43 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Run Infinity-Box software, select model "MT6228" and make "format". More details: http:///vbb/showthread.php?t=476373 |
The Following User Says Thank You to InfinitySupport For This Useful Post: |
02-19-2008, 16:29 | #11 (permalink) |
No Life Poster Join Date: Nov 2005 Location: TIRUPUR
Member: 202500 Status: Offline Thanks Meter: 234 | pda a818 again problem unable to formate / read/ only error message on display COM1 selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 error: bootcode load error: FFFFEAFF00780000E3A0004078607C4078810088A01D50E281 1004E240D001C1A02366EB000079E613E10A143540006D607C 002BBD8048F74770B5B06CC260D46A511D05682318043440CD 2468097A202802D105201302C0800040028302032801D10C02 C08008208780182007801820010380800820004840A0293C00 A2AF838108220262020220D3F848C380288810230243188010 200002300104000020D3FA08CD7B1021804300AE22AF02AE04 05801A20A0293C20A0115080080044CD40C102FFA120047220 200083A98361051C046A4A344060156AC8CA0A3A0868927A20 2802D105201302C0802820028018E0022801D10A02C0802823 80800B20000801988028200057780112706F2C0C4041404340 0895323F090183424302821A40010820000014780008220262 02022092DA49B87B081C024318730020E98DAD094501002A3C 2020108001480429CD20C102FF5A20047220006F2C08919B02 23308720839187203C102CE505C10DE105E905A90161F8E004 780B310170033000085200872000141720060005C105094093 BB4670B5FF1C0E1C011C16020FA19CB081F7FFFFD018A419EF E007220F1C20A197F00CFBD5280012198042A7D8F5E00E220D 1C208196380DF7FFFFC4220D1C20A1923805F00CFBC3280002 1BA442ACD8EE42ACD90142A7D81B200004A1A90944D0034883 3002B005BDF030012801D3F4682143CB2000ADA1A00928D002 487C3004E7F03000A1684648793003E7EA900428000299041B 60600820009C5E1B03D2022005E5487CE000624A6225AD0828 0488B132002B4C22023704C28005A5FDD1B2097664C8780083 A8C30F7346846CF868C66CF12873468E6D716CB46DB5683294 005B6D1304D8B9014502485F3001BDF80E6970000D0D9602E9 280704026B38467460002D172C830DBF33202C030B00A18D0D 116DADE1089110910D61432060102000084240D3FC20016008 20000A4240D3FC6BB84398032040102604600E20000A4240D3 FC6B78439843206010400E2000084240D3FC0024002D8101C1 05A121D3FC32012A08D3F721016C3807C943086028000A4240 D3FC2000DE4B010847A4350104C70068C21810684060012000 0447DB483DB0833810600160404D3B910190026CE81C1F68C0 6D006620322024200E813310072856042181E1B1A168C13140 70092800742029124310DB40836AC068C11C20F00CFAE81C06 D16524006A6989010C2868210A218594A51020D008A8014D25 1D00A50920D05878694288D054A8015D00DFFF571C06D14CA8 015D0049420A027401530740705B7A5A3056018020098880B8 FFFED0220F1C28A10DF7FFFCB3220F1C28A102F00C Release Power button now ! Boot Fail Finished, time used: 8 sec Remove/Install battery now ! |
02-28-2008, 15:13 | #13 (permalink) |
Member: 202500 Status: Offline Thanks Meter: 234 | [QUOTE=ashok_kumar459;3100060]pda a818 again problem unable to formate / read/ only error message on display COM1 selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 error: bootcode load error: FFFFEAFF00780000E3A0004078607C4078810088A01D50E281 1004E240D001C1A02366EB000079E613E10A143540006D607C 002BBD8048F74770B5B06CC260D46A511D05682318043440CD 2468097A202802D105201302C0800040028302032801D10C02 C08008208780182007801820010380800820004840A0293C00 A2AF838108220262020220D3F848C380288810230243188010 200002300104000020D3FA08CD7B1021804300AE22AF02AE04 05801A20A0293C20A0115080080044CD40C102FFA120047220 200083A98361051C046A4A344060156AC8CA0A3A0868927A20 2802D105201302C0802820028018E0022801D10A02C0802823 80800B20000801988028200057780112706F2C0C4041404340 0895323F090183424302821A40010820000014780008220262 02022092DA49B87B081C024318730020E98DAD094501002A3C 2020108001480429CD20C102FF5A20047220006F2C08919B02 23308720839187203C102CE505C10DE105E905A90161F8E004 780B310170033000085200872000141720060005C105094093 BB4670B5FF1C0E1C011C16020FA19CB081F7FFFFD018A419EF E007220F1C20A197F00CFBD5280012198042A7D8F5E00E220D 1C208196380DF7FFFFC4220D1C20A1923805F00CFBC3280002 1BA442ACD8EE42ACD90142A7D81B200004A1A90944D0034883 3002B005BDF030012801D3F4682143CB2000ADA1A00928D002 487C3004E7F03000A1684648793003E7EA900428000299041B 60600820009C5E1B03D2022005E5487CE000624A6225AD0828 0488B132002B4C22023704C28005A5FDD1B2097664C8780083 A8C30F7346846CF868C66CF12873468E6D716CB46DB5683294 005B6D1304D8B9014502485F3001BDF80E6970000D0D9602E9 280704026B38467460002D172C830DBF33202C030B00A18D0D 116DADE1089110910D61432060102000084240D3FC20016008 20000A4240D3FC6BB84398032040102604600E20000A4240D3 FC6B78439843206010400E2000084240D3FC0024002D8101C1 05A121D3FC32012A08D3F721016C3807C943086028000A4240 D3FC2000DE4B010847A4350104C70068C21810684060012000 0447DB483DB0833810600160404D3B910190026CE81C1F68C0 6D006620322024200E813310072856042181E1B1A168C13140 70092800742029124310DB40836AC068C11C20F00CFAE81C06 D16524006A6989010C2868210A218594A51020D008A8014D25 1D00A50920D05878694288D054A8015D00DFFF571C06D14CA8 015D0049420A027401530740705B7A5A3056018020098880B8 FFFED0220F1C28A10DF7FFFCB3220F1C28A102F00C Release Power button now ! Boot Fail Finished, time used: 8 sec Remove/Install battery now ! sloved the problem need to keep boot mode in setting please keep 2 and formate u solve the problem nand 6228 |
02-28-2008, 19:03 | #14 (permalink) |
Product Supporter Join Date: May 2005 Location: uae
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, sometimes autoselect of baud rate is giving unstable booting. in this case worth to try to disable it and try different booting steps thank you for sharing this! |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
Can't Read Unlock for from New Bleu 145x | [Shadab_M] | ET-BoX | 4 | 06-18-2009 16:52 |
Cu720 Not support version! Dump firmware and send to support! | caremobiles | Z3X-Team Products | 5 | 04-03-2009 06:35 |
Problems for GO TO SUPPORTS | ar-tel | FuriousGold | 9 | 05-10-2007 12:41 |
absolute newbee question: how to read fullflash from phone to file? | rostfrei | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-01-2006 22:00 |
flash out send to [email protected] | gsminfo | SagMaster Team OLD Products | 0 | 06-06-2004 13:03 |
