02-05-2010, 21:13 | #1 (permalink) |
Banned Join Date: Oct 2005 Location: www.cilianunlock.com
Member: 194420 Status: Offline Thanks Meter: 15 | Repair SECURITY_TEST failed! correct http://www.4shared.com/file/21579721...ST_failed.html |
The Following 6 Users Say Thank You to cilian For This Useful Post: |
02-05-2010, 21:25 | #5 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | not wotking at this timei try before some time this is old video -------------- Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 92.98.98.248 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Last edited by chand_gee; 02-05-2010 at 21:32. |
02-05-2010, 21:43 | #9 (permalink) | |
Member: 194420 Status: Offline Thanks Meter: 15 | Quote:
The Following User Says Thank You to cilian For This Useful Post: |
02-05-2010, 21:52 | #10 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-303_358976017297242_SD.RPL" Updating SUPERDONGLE_KEY ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 92.98.98.248 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-06-2010, 00:00 | #11 (permalink) | |
Freak Poster Join Date: May 2009 Location: venezuela Age: 32
Member: 1027249 Status: Offline Thanks Meter: 24 | a38 Quote:
which got the solution to SECURITY TEST FAILED Nobody believes this solution only for not wanting to download and test | |
The Following User Says Thank You to a38 For This Useful Post: |
02-06-2010, 02:16 | #13 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | see here maybe this can help http://forum.gsmhosting.com/vbb/showthread.php?t=920173 good luck WBR adelakah25 |
02-06-2010, 04:31 | #14 (permalink) | |
Member: 1027249 Status: Offline Thanks Meter: 24 | Quote:
write lines CCC HWC And then sx4 and write the entire PM you add this http://www.4shared.com/file/21598259...e_datos_R.html Tested on Nokia N78, 5220, N82, 5130 | |
after sd repair SECURITY_TEST failed! | mobitechnepal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-18-2010 14:15 |
after sd repair SECURITY_TEST failed! | mobitechnepal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-18-2010 10:20 |
7210 after SD repaire SECURITY_TEST failed! ?? | communication_expert | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 02-06-2010 13:56 |
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 11:36 |
Mr MANOLE When will be he next update to repair SECURITY_TEST failed! bug | 4given4gotten | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-05-2010 12:43 |
