x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-21-2003, 00:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | c45 wrong software any idea? thanks |
03-21-2003, 22:37 | #3 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi, i have seen the problem was that there was something wrong in the board and when i press, the phone switch off. but now i rehot the power ic, the flash ic and the microprocesator and when i go to switch on, the phone is dead, i reflashed the phone with a copy of the flash and dead, and when i read the phone the flash type has changed. any idea?, thanks |
03-23-2003, 16:30 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 40
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | man in the first u make mistake when u open the phone and make this things in it when u have wronge software this means u have proplem with imei and u need to repair it by map file but u open the phone. now try to flash the phone be good flash file and eeprom file and then make log from ur phone using logger and send for me the log file i will colclate for u the map. if u don't have good flash file and eeprom for it contact me online i will send for u the flash file and eeprom to use it with unisiemens. best regardes, [email protected] icq : 111473016 |
03-24-2003, 01:08 | #6 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
03-25-2003, 21:48 | #8 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi, i did how gforce say in the post, with the start c45 tool when i read info appears very estrange dates (strange symbols), with another programs it give me diferent things: with siemens flasher 4.89 it give me flash model 2068, phone ID=556E6B6E with siemens flasher 1.2b it give me flash type fc-80-fc80 now i try to flash with all3/4 v2.10 cracked by rios with c-45-06 3 12.flx and when i init mobile it tells me "flash HC=8080 unsupported, flash configuration or wrong type selected i have a backup of this phone but is in format *.bin, well i try to to put this backup with siemens flasher 4.89 and finish in the 99% of the flashing and phone still dead. but when i put this backup with unisiemens the flashing is 100% but still dead in the beginin before dead, when i read the phone gave me flash=c489, phone ID=6BB410D4 and one question, is posible to change bin files to flx?, thanks for all your help |
03-26-2003, 01:34 | #9 (permalink) | |
Like I said, you might damaged the chip... | |
03-26-2003, 21:03 | #10 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | i did rehot another phones without problems, and i did rehot this because the phone works well but if i press too much one key in the call key zone then the phone switch off, i saw that bellow that zone are the microprocessor, the memorys and the power ic, then i though that there was a problem in some board line or some bga ball that is the reason of the rehot thanks for your help |
04-02-2003, 23:44 | #15 (permalink) |
No Life Poster Join Date: Nov 2001 Location: morocco larache Age: 51
Member: 7334 Status: Offline Sonork: 100.112291 Thanks Meter: 47 | hi friend , flash your c45 and reunlock it with ksi siemens craked and it's ok go to: www.chavalgsm.com if you dont have ksi siemens program ... good luck |
C45 wrong software need a map file or a hammer to flatten the phone | indel306 | Phone Unlocking Codes & Maps | 1 | 11-17-2002 15:02 |
C45 Wrong Software report | Talgat | x1x to x45/x50 | 0 | 06-19-2002 22:50 |
HELP!!! C45 Wrong Software after Upgrade | Max468 | x1x to x45/x50 | 3 | 06-12-2002 20:58 |
c45 wrong software | sonkar | x1x to x45/x50 | 4 | 05-13-2002 09:26 |
c45 wrong software,help? | gsmsalers | Phone Unlocking Codes & Maps | 6 | 05-07-2002 22:15 |
