Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
10-02-2003, 09:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2003 Location: SL 550 Age: 48
Member: 20490 Status: Offline Thanks Meter: 3 | C55 switch off. |
10-06-2003, 06:36 | #3 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | if in some sl45 case, it would be the clock crystal that cause this, also found some case with defective - loose connection bga to board - or lost link from cpu to flash ic |
10-06-2003, 19:02 | #4 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | same problem, have a55 auto shut off. the time is random, but about 30 second always off. but when i use it for calling, its okay, why ?? dialog, flash, ram, cpu has been chaNGED. HELLPPP |
11-07-2003, 13:28 | #10 (permalink) |
Member: 20490 Status: Offline Thanks Meter: 3 | This is the story, exactly! 1.I flash/eeprom/log/map/load map it to V18(same flash ic hardware=software) and same problem! 2.I change RTC & without testing i reball Dialog IC. Now everything OK at 101%. |
11-11-2003, 16:38 | #12 (permalink) |
Insane Poster Join Date: Feb 2003 Location: indonesia Age: 46
Member: 23333 Status: Offline Thanks Meter: 0 | i have try s55, if the memory is full (phone book, sms), it's some time powering of outomatic. after erased it, start working fine. so my gest if repair with flasing, use ful flash. not just upgrading. or just empty the memory |
c55 switching off when 4 pressed | jongo | DreamBox | 2 | 11-23-2006 17:24 |
c55 switched off after light | freshwhite | E-Gold Based Phones | 2 | 07-12-2005 16:24 |
3310 after switching off, will only switch back on if you remove and replace battery | bilbo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-2003 00:41 |
T65 switch on ... switch off ... switch on ... switch ....... | MiSi3k | Sony Ericsson | 8 | 08-17-2003 00:45 |
c55 switch off after unlock | desbloqueo | E-Gold Based Phones | 0 | 05-06-2003 18:39 |
