Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 09-16-2004, 09:52   #1 (permalink)
Member: 29457
X70 restarting
I have very strange problem with many X70.
If the vibration alert is switched on, the headset restarts ( switched off and on itself ). I replace vibrate motor and upload different software version ( A31,A32,A34,A36) but problem is stay also.
Do you know any solution?
Old 09-16-2004, 10:08   #2 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
phone restart when became to vibrate??maybe water damage.try to resolder the batery conector.
Old 09-16-2004, 10:16   #3 (permalink)
Member: 29457
No water damage, this is new phones (many). I replace and batery conector with new one, but problem is stay.
Old 09-16-2004, 10:49   #4 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
phone restart only when vibrate?
Old 09-16-2004, 10:55   #5 (permalink)
Member: 29457
Yes, that's right.
Old 09-16-2004, 21:02   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
heheheheheh
Solution is very Simple
Just Download the X70 Clear Script & copy it to Cb2000 1.5 Folder
Connect the Phone
click on the Arrow ( Arrow goes to Phones )
There you can find the "Clear memory" option
just do it twise ot Thrice
Power Off Your Phone
ALL IS OK
tested 100%
Old 09-19-2004, 10:35   #7 (permalink)
Member: 29457
Aamir,
I try your solution on 5 pcs, but problem is stay.
Old 09-19-2004, 13:04   #8 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
do u download the X70 Clear Scripts ??
do the screen shows "Default Passed"
Old 11-26-2004, 10:50   #9 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
Did anyone solve this problem please??
I have some new phones with same problem. Tried to upgrade sw with Pana-extreme but still same problem!
Where can I download the X70 clear scrips Aamir_Zia??
tonytony
Old 11-26-2004, 11:18   #10 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
@Aamir_Zia
i find Cscript on C:\WINDOWS\COMMAND
is this file which u said
Rise
Old 11-26-2004, 11:42   #11 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
No I would like to know from where to download them first??
Are there any pana-extreme users here?? I have a few questions please!!
tonytony
Old 11-26-2004, 20:00   #12 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
problem is bad contact between batery connector and pcb.also one more symptom is charging led blinking when you charge the phone and the batery is almost empty.
you can't solve the problem just with contacts cleaning,you must solder the pcb contacts(use solder wire without flux).
Old 11-26-2004, 20:38   #13 (permalink)
Member: 83073
Are you sure?Becouse I have the same problem with my new X-70 and alredy send them back to shop but the same problem remain.Please give some more details and I will fix it by myself.
Thanks Dejan
Old 11-26-2004, 21:38   #14 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
don't do that,you will loose your warranty(just in case for the future)
Old 11-26-2004, 21:49   #15 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
i mast tell you that i spend too much time to find this solution.before 1 month i send e-mail to mathuchita(panasonic) for this,they congratulate me and they will release new batery contacts(largest).so wait for that.
x70 restart on pictures folder Y2ksalman Infinity-Box 3 12-03-2006 17:54
X70 Restart...relock... Ushimata59 Panasonic 3 07-31-2006 16:21
x70 restart itself george gsm Panasonic 1 07-12-2006 22:28
X70 restart problem after unlock tical Infinity-Box 10 09-14-2005 08:42
X70 restarting TheBrain Panasonic 10 06-08-2005 11:58
Page generated in 0.21175 seconds with 9 queries
