Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 01-29-2005, 06:57   #1 (permalink)
clinic*mobile's Avatar
Member: 20833
Thanks Meter: 5
Arrow sharp gx20 unlock
Hi
how unlock sharp gx20
where i found correct shematic cable for gx20
i made cable but dont work with porogram ****** 3.1
br
thanks
www.clinicmobile.com
Old 01-29-2005, 09:24   #2 (permalink)
kaaniletisim's Avatar
Member: 79065
Sonork: 100.1646746
Thanks Meter: 79
Thumbs up gx20 unlock
test by KAAN-İLETİŞİM 100%100 ok
Old 01-29-2005, 09:35   #3 (permalink)
Member: 20833
Thanks Meter: 5
THANKS for replay kaaniletisim
check with program but dont work
i think my cable have problem
do you have correct shematic
The Following User Says Thank You to clinic*mobile For This Useful Post:
Old 01-29-2005, 09:41   #4 (permalink)
Member: 79065
Sonork: 100.1646746
Thanks Meter: 79
gx 10 cable test ok
Old 01-29-2005, 09:42   #5 (permalink)
spguru's Avatar
Location: A O T E A R O A - Land of the long,white cloud
Member: 8985
Thanks Meter: 3
Gx20 totally different then gx10.Only schem which works what you posted.expain what happens...cable pinout should be ok.
try v.i.l.a.n.i soft!
Old 01-29-2005, 09:53   #6 (permalink)
Member: 20833
Thanks Meter: 5
thanks spguru
is my shematic ok
i saw in shematic ****** that pin 3 not connect to gnd
but pin 9 connect to gnd
do you have correct shematic cable
br
Old 01-29-2005, 21:47   #7 (permalink)
spguru's Avatar
Member: 8985
Thanks Meter: 3
You must be talkin' about this pinout:
KEY PAD
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
pin 1 gnd (black)
pin 2 link to 10
pin 5 + (red) ext power +3..5V
pin 5 link to 12
pin 6 rx (white)
pin 7 tx (blue) open drain, connect 10k Resistor to pin5!
pin 9 link to 14
If so the pinout above is for Gx10/Gx10i for unlocking,flashing but that pinout above doesn't work with Gx20.I had that first then got problem with Gx20.I have modified the cable to the pinouts of your attached picture.Everything went fine afterwards.Use the soft I have enclosed that will work.Let it go,the process is about 2-3min it may look like not doing anything.Don't disconnect until it says OK otherwise the phone will be stuffed!You must use +5V on those pins,open drain on Rx-Tx by 10K resistors is important too!
GD luck
Remove txt extension from the end of the zip... If didn't work you may want to try with gx10 pinout if wanted but I don't think that will work the other way around like mine.
The Following 2 Users Say Thank You to spguru For This Useful Post:
Old 01-30-2005, 20:40   #8 (permalink)
Member: 20833
Thanks Meter: 5
thanks for replay spguru
do i must be power on my phone when unlocking or must be off
how unlock plz help me step by step
thanks
Old 01-30-2005, 22:42   #9 (permalink)
spguru's Avatar
Member: 8985
Thanks Meter: 3
thanks
See PM also don't ignore the 5V
Old 02-01-2005, 10:49   #10 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
hello.
for unlock with this software it's easy, power on phone with out sim card, and clik on unlock, wait , the phone power off and the software tell clik on , clik on , and clik on seconde time, and wait 40 seconde, the software tell you the phone it's ok no, clik ok , and disconnect all.
after 5 or 6 run, the softwre tell me need registration, have solution with out register pls ?
Old 12-26-2008, 17:46   #11 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
thanx nice work can i used any device for flashing all shrap models
Old 05-30-2012, 07:35   #12 (permalink)
Member: 528610
Thanks Meter: 4
dear friend please help me to unlock 1 sharp gx20 step by step thank in advance
Old 05-30-2012, 16:40   #13 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
search forum its old story
Sharp GX20 - Unlocked - "Emergency Calls Only" moonklash Sharp 5 06-15-2005 05:54
sharp gx20 unlock code RICSIL Phone Unlocking Codes & Maps 0 11-21-2004 15:36
sharp gx20 unlocker by ****** stukachu Sharp 72 10-24-2004 11:22
Sharp Gx20 Unlock Problem GreekMobiler Sharp 4 08-22-2004 16:47
Sharp GX20 unlock...no NCK code in list ....what to do?? boni Sharp 5 06-08-2004 18:16
Page generated in 0.24481 seconds with 10 queries
