04-20-2005, 01:37 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 24
Member: 137411 Status: Offline Thanks Meter: 1 | There is such a patch for sl4x v.5508 Chinese version. 256E22: DAC5825D DABFD061 1F61D0: FFFFFFFFFFFFFFFF 8810DAC5825DD740 1F61D8: FFFFFFFFFFFFFFFF 0E00F2F1423A9AF1 1F61E0: FFFFFFFFFFFFFFFF 0100E0249810DB00 ;1F61E1 Applications option menu 1 ;Applications option: menu 1 by default 0x450020: B31FFEB07D95310000000000 FEA201FE99289553494D0000 The flash will disable the use of Sim card when you select the option. |
04-20-2005, 10:57 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 52
Member: 9891 Status: Offline Thanks Meter: 2 | If you use these patches: - FAV: Favorite Menu (or its "brothers") - PWS: Phone Without SIM-Card then you can add these lines in your FAV entry : ... edited After you execute that, the phone will act as our card is rejected ... Make an Emergency Call, press [Yes], and the [RED] button to go to the main screen. In my trial, we must restart the phone to connect to the network again ... rizapn Last edited by rizapn; 04-20-2005 at 15:56. |
04-23-2005, 03:03 | #8 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 44
Member: 133211 Status: Offline Thanks Meter: 4 | @rizapn - FAV: Favorite Menu (or its "brothers") - PWS: Phone Without SIM-Card then you can add these lines in your FAV entry : ... edited After you execute that, the phone will act as our card is rejected ... Make an Emergency Call i apply this patch patch now. i can't under stand your note EX in this patch. The menu item data format is: ;SSS.AAAAAA, where SSS is 3 digit string ID for menu item, ;and AAAAAA is 6 digit entry-point for that item. ;For example: 2d6.d8e1d6 for Currency Conv. function. ;Put a single space between each menu item data. i try by step your EXAMPLE it correct to 2d6.d8e1d6 for Currency Conv. then you can add these lines in your FAV entry : ... edited After you execute that, the phone will act as our card is rejected ... Make an Emergency Call but i write your way it not show to emergency call How To know another cod and another function ? i can't under stand it can you show another code and command to me for check and lern it all command Thank you very very much that make many patch for SL45 P.S. i write in lines in your FAV entry : ... edited not show emergency call it show +List i'm very confuit Thank again |
Thread Tools | |
Display Modes | |
When new update ?? ?? ??If you don't want update this box pleasse close this section | wgmmmx | Federal One | 12 | 01-19-2008 18:23 |
Amazing Prices for All Dealers in India!! Ask for Prices Even if you dont want to BUY | nonu_don | Main Sales Section | 0 | 10-25-2007 14:26 |
Amazing Prices for All Dealers in India!! Ask for Prices Even if you dont want to BUY | nonu_don | Main Sales Section | 0 | 10-14-2007 10:13 |
If u don't want to see ur phone dead keep this in ur mind | hasnain | BB5BOX | 4 | 10-05-2007 08:13 |
Can someone calculate 2 logs for me ! If you don't want to, I won't mind ! | mr_x4you | Phone Unlocking Codes & Maps | 0 | 01-31-2002 18:02 |
