04-29-2005, 17:28 | #1 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | :: Update 29th April 2005 :: X66 Russian & A100 Bulgarian Flash files added X60, X66, X68 X6xA40_Ru_Fr_Es.07M (FIRMWARE) A100, A101, A102 A100_021_Main.03M (FIRMWARE) A100_021_LP6.L04.01_Bg_Tr.03P (LP) A100_021_Map_bgu_01.M08.01.03F (MAP) Best Regards Infinity-Box Team |
07-06-2005, 19:41 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Italy Age: 51
Member: 13643 Status: Offline Thanks Meter: 23 | I have flashed a x60 with the Russian file.Now I have a problem : the phone doesn't ring . Obviously I have controlled the hardware. What I must make? BR Copernico |
07-06-2005, 20:52 | #3 (permalink) | |
You have to flash FFS part, not only MAIN. B.R. InfinitySupport | |
07-07-2005, 09:00 | #4 (permalink) | |
Member: 13643 Status: Offline Thanks Meter: 23 | Quote:
X6xA40_Ru_Fr_Es[1].07M X6xA40_FFS_Decustomized[1].07F.bin AFTER I HAVE FLASHED PHONE WITH ORIGINAL FLASHER AND ITALIAN FLASH PACKAGE VER. A60 . PHONE STILL DOESN'T WORK . I HAVE A QUESTION : CAN I FLASH PHONE WITH OTHER PHONE BACKUP ? BR COPERNICO | |
07-07-2005, 12:00 | #5 (permalink) | |
It's impossible to flash other phone backup directly using Infinity-Box. If you have good backup, send it to us, pls, and we will upload it into support area after our test. You can send good backup here: InfinityHelp at yahoo.com.hk Also, as about your phone. Try to make "Reset settings". Also, try to flash with other flash files (MAIN+FFS). In fact, many phone problem can be repaired with good FFS flashing. Also, pls, decribe the problem more exactly. What do you mean "no ring" ? Can you select different ringtones via menu ? Also, are you sure that phone was 100% ok before first flash attempt ? B.R. InfinitySupport | |
:: Update 29th April 2005, Nec N342i support added | Infinity-Box | Infinity-Box | 24 | 06-25-2009 01:48 |
Update 10th April 2005 :: GD55, X400, X66 New flash files uploaded : : | Infinity-Box | Infinity-Box | 3 | 05-08-2007 08:11 |
..:: Updates 20-06-2005 ::.. | Thunderstorm | ThunderStorm Box | 0 | 06-20-2005 01:57 |
..:: Updates 15-06-2005 ::.. | Thunderstorm | ThunderStorm Box | 2 | 06-16-2005 05:07 |
:: Update 28th April 2005 :: X70 repair instruction for DEAD phones : | Infinity-Box | Infinity-Box | 14 | 05-01-2005 00:31 |
