S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
05-25-2005, 20:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | Unlock and repair x65 v41 series 100% tested that can't be downgraded via winswup or cannot be repaired by normal ways... you can use this method 100% tested all steps (and tp pics) at http://babelfish.altavista.com/babel...26highlight%3d it's a bit complicated but this is better than nothing little explanation: 1. Make tp 2. Run papua's soft and get imei/esn HASP (last option at right, use button located at bottom) 3. When it's detecting and shows something like "2" or "1.5" then disconnect test point---> it will detect imei perfectly 4. Then go to 2nd option of papua's soft and use 4th button (Skey é Bkey) 5. Save it for vklay 3.x 6. USE THIS SAVED FILE AS LOADER FOR X65 SERIES IN VKLAY LOADERS FOLDER 7. run vklay 8. Fullflash or patch or what you want with your phone withouth problems , if you have problems dont care, retry and retry (I have used 1 time for sl65 and 3 times for s65) work 100% with v41 new bootcore this is not for unlocking 10000 phones but is really good for unlocking few phones that martech can't do and for repairing damaged phones (eeprom tools damaged by write all, etc) get lucky Regards Thecult |
05-25-2005, 20:50 | #3 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Poland,Germany Age: 43
Member: 18846 Status: Offline Thanks Meter: 0 | Solution likes good but what i should to do after step (8) to unlock phone ? When patching then need patch files .... please xplain smething more THX! BR...........Maxtor |
05-25-2005, 21:32 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 46
Member: 78018 Status: Offline Thanks Meter: 4 | you do not need to downgrade soft! after step 4, on first tab papua start service mode, you will saw service mode started, secuity status "Customer mode", then use send skey buton , and phone will open security status "Factory mode", (wich meen that ful eprom is opened) then save freia log, calculate map, run epprom tools upload map! procedure over! if phone don't open security status "Factory mode", that meen that in phone is not original epprom block 5122, and you need to patch flash to open eeful!!!!! |
05-25-2005, 23:37 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Europe Age: 39
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | Thanks man..Todey i sucefuli unlocked my cx65 v.41 by your totorial..I am very happy.... Its work fine...I do it with x65papuautilsv024a.... |
05-26-2005, 00:53 | #6 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: London Age: 46
Member: 42036 Status: Offline Thanks Meter: 6 | Quote:
05-26-2005, 08:07 | #10 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Quote:
And Papuautils Presented by @the cult, is the only working free sollution at the moment. And it works. br huzsolt | |
05-26-2005, 09:47 | #12 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | thanks huzsoft some ppl don't know that exists x65 v41 that cannot be downgraded directly... phones with new bootcore cannot be downgraded/unlocked/patched directly, independent of what kind of cable you use the only way, for the moment, is this method (or martech II) ... and by this way you can repair 90% of phones damaged too |
05-26-2005, 09:48 | #13 (permalink) | |
Member: 9700 Status: Offline Thanks Meter: 62 | Quote:
solution is hard for unlocking (1 hour flashing in step 8 at least)... but after it you can unlock direct with any free soft b.r. | |
!!free fast and easy DEAD BB5 FLASHING,100% tested by me!! | jawad8305 | Nokia Base Band 5 ( BB-5 ) | 233 | 02-26-2012 10:38 |
TESTED,successfull unlock and repair bb5 by UB here: | kadekrudi | Universalbox | 2 | 11-25-2009 08:27 |
unlock and imei Samsung c425 / c426 100% tested | cellcarcol | Z3X-Team Products | 0 | 06-07-2009 18:23 |
e720 unlock and repair 100% | kham | Trident/AGERE Platform | 8 | 07-05-2005 02:38 |
FREE UNLOCK FILES FOR T191(v 171 ) 100% tested and OTHERS SOFT :) | enemy | GSM Mobile Links | 2 | 06-16-2002 01:20 |
