Old 06-19-2005, 13:40   #1 (permalink)
Member: 130995
Thanks Meter: 35,227
UPDATE 19 JUN 2005: GD55,G5x,G70,A10x,X300 v1.25
UPDATE 19 JUN 2005:
[+] New flash chip support
[+] Initial communication improved
[+] Communication port selection improved
B.R.
InfinitySupport
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 06-19-2005, 13:47   #2 (permalink)
Member: 65975
Thanks Meter: 22
Thank you Guy , keep it up.
Best regards.
Old 06-19-2005, 14:02   #3 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
Infinity team keep it
ur always on top
thanks & regards
Zafar Janjua
Old 06-19-2005, 18:32   #4 (permalink)
Member: 47236
Thanks Meter: 58
as i see at the site here is other update today too
19 JUN 2005: Infinity-Box Bird S1180C/S1120/V09/V10 v1.03
but the .rar is corrupted infinity team can you uplaod goodone?
best regards
Old 06-19-2005, 20:23   #5 (permalink)
Member: 130995
best regards
Hello !
Thanks for info !
Good archive was uploaded 3 min ago.
It was no any important changes in Bird v1.03 (only small internal changes, no new functions added) so we did not make any anounce about this update.
B.R.
InfinitySupport
Old 06-20-2005, 22:29   #6 (permalink)
Member: 112934
good work,keep it up
Old 06-28-2005, 17:03   #7 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
hi
i am having problems to run v1.25
every time i open it, it gives me an error called
ERROR:87
I have tryed to run this program from
C/PROGRAM FILES/INFINTYBOX/PANA
and it gives me same error
i have created a separete folder and tried from there and gives me same error
any idea infinity team
all other programs are working fine
br
Old 06-28-2005, 23:44   #8 (permalink)
Member: 130995
Originally Posted by chowdary
hi
ERROR:87
br
Pls, send me log file to mail: InfinityHelp at yahoo.com.hk
We will check it ASAP.
B.R.
InfinitySupport
Old 06-29-2005, 16:45   #9 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
Originally Posted by InfinitySupport
B.R.
InfinitySupport
thanks for your reply
i have checked in log file it doesn't show any error there
it only gives when i open the program
now when i open it shows a box saying error:87 and it gives a option to press ok
till i don't press ok it doesn't open program
i will still send u log file to have a look
thanks
br
Old 06-29-2005, 17:12   #10 (permalink)
Member: 130995
thanks
br
Please, try to make this: remove file Setup.ini (from the same folder where software located) and start software again.
It can be that wrong COM-port No was saved in the ini file.
Also, pls tell me what OS installed on your PC ?
And in any case, pls, send me Log file to check.
B.R.
InfinitySupport
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 zulea Others (USB-Smart) 0 04-03-2006 16:44
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 zulea Panasonic (USB-Smart) 0 04-03-2006 16:43
UPDATE 26 AUG 2005: Panasonic GD55/G5x/G70/A10x/X300/A210/SC3 v1.27 InfinitySupport Infinity-Box 5 08-26-2005 17:24
UPDATE 28 JUL 2005: Pana GD55/G5x/G70/A10x/X300 v1.26 InfinitySupport Infinity-Box 10 07-29-2005 10:57
UPDATE 27-APR-2005: GD55,G5x,G70,A10x,X300 v1.14 InfinitySupport Infinity-Box 4 04-27-2005 16:12
Page generated in 0.20288 seconds with 9 queries
