06-25-2005, 14:26 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | "Error flashing block at address:" - why?
Please don't blame Cruiser when you get this error. |
06-25-2005, 14:43 | #2 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | The voltage between VPPFLASH and GND pins should be around 3V, within 10% tolerance. If your cable provides another voltage (for example 5V), you will encounter flash errors. The voltage of 9.15V is probably not supported by your cable design and you may very easily damage phone hardware. |
01-31-2006, 10:05 | #3 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | You may encounter this error when converting new HW revisions of red CID49 K60x/V600/W900/W550/W600 phones to brown CID49. These phones are not supported for non-TP conversion to brown yet. Use a TP method instead. These two lines indicate new HW type: Applet error: ERROR|EraseBlock| 04 FF FF FF 43 Applet error: ERROR|EraseBlock| 04 FF FF FF 1F Other values indicate hardware failure. Last edited by Lead; 02-04-2006 at 12:34. |
02-21-2006, 00:24 | #4 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | Code: Programming flash... Error flashing block at address: 0x50010000 Script error: Flash error [x.xx.xx] This fails because of 2 reasons:
Need HELP K790i flashing | Error flashing block at address: 0x44140000 | galerinisan | Cruiser Suite | 4 | 06-03-2008 18:06 |
W810 dead after failed flash (Error flashing block at address: 0x444B0000) | Xflame | Cruiser Suite | 12 | 12-11-2006 04:27 |
"Error flashing block at address:0x44022400" in k750 | begginer | Cruiser Suite | 17 | 08-02-2006 22:04 |
k500i Error flashing block at address: 0x450C0000 | ber747 | Sony Ericsson Hardware Repair | 5 | 04-28-2006 13:14 |
Error flashing block at address :0x2D000000 for W900i | DrilleR | Cruiser Suite | 2 | 01-28-2006 18:42 |
