08-02-2005, 09:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: The Netherlands Age: 40
Member: 58493 Status: Offline Thanks Meter: 24 | Philips 350 unsupported Please take a look at this one, philips 350 not supported. Reading flash is not possible, Flash mode gives "timeout" |
08-06-2005, 15:22 | #3 (permalink) | |
Freak Poster Join Date: Feb 2003 Location: Craiova(Romania) or www.alfamo Age: 45
Member: 22553 Status: Offline Thanks Meter: 7 | Quote:
please read full flash file and send to: [email protected] Regards! | |
08-06-2005, 16:54 | #4 (permalink) |
Member: 58493 Status: Offline Thanks Meter: 24 | When I select Philips 350 and press "Flash mode"I get error: "timeout" When I select Philips 355 and press "Flash mode" it works and I can read flash... strange but can i read fullflash from philips 350 with philips 355 selected in zealot? |
08-06-2005, 18:05 | #5 (permalink) |
Member: 22553 Status: Offline Thanks Meter: 7 | Hello, please use the JACK cable for 350 and 355, and press short button when you try to put in test mode( power button). Please read full flash and send to : [email protected] and we can make update for you soon. Regards! |
08-06-2005, 21:37 | #7 (permalink) |
Member: 58493 Status: Offline Thanks Meter: 24 | I do use JACK for unlocking these types , and I use 2.1. I try to explain, I can only read flash from 350 when I select 355 in program, otherwise it does'nt work (it gives "timeout when I try to read it with 350 selected). Are both 350 and 355 thomson 8 mb? |
08-07-2005, 13:07 | #8 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | for unlock model 350 and 355 you can use JACK , but for read flash or write flash you need : open phone and sold Rx Txand GND inside phone or use special cable with jitag no other solution for read flash |
08-12-2005, 13:23 | #10 (permalink) |
Member: 22553 Status: Offline Thanks Meter: 7 | If you readed already you can send to [email protected] and will make update for you soon. You can send me the flash files also via sonork. Regards! |
08-12-2005, 15:54 | #11 (permalink) |
Member: 58493 Status: Offline Thanks Meter: 24 | I have send it to [email protected] a few days ago otherwise download it here: http://www.savefile.com/files/3066430 |
Julvir, what about the philips 350 unsupported ? | chavrotti | Redbox | 0 | 07-06-2004 12:56 |
New Free Update: Philips 350 - Flashing, Unlock, Repair - Alcatel - Sendo | DELOK | Main Sales Section | 0 | 02-26-2004 02:21 |
Philips 350 Supported in P-Toolz v1.02 ! ! ! | Gsm Experts | Main Sales Section | 0 | 02-19-2004 16:38 |
Need Unlocking Solution for Philips 350 | GPGIndustries | Wanted Products | 0 | 02-12-2004 17:51 |
philips 350 [ct 3508] pin out& unlock | postapos | Philips | 0 | 02-10-2004 21:27 |
