08-04-2005, 13:20 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | i Can't Unlock E101 With Infinity i try with all cable G50 ( i cut plastic ) T191 X60.. with 5V without 5V and Phone stil Not detected ... Phone is New some can help m ReGards .. Faisal !! |
08-04-2005, 13:28 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, cut plastic more and to be sure that connector fit into E101 completely. You need to use cable with "G50" mark. No need to use T191/X60 cables. Use our UniBox, connect it to PC via USB, connect cable into left RJ-45 slot. |
08-04-2005, 16:34 | #5 (permalink) | |
What do you mean 5V ? What cable you try to use ? If you use our cables you don't need any external power for cable. Please, describe exactly what are you doing. And some advices: 1. Check COM port selection. 2. Do you see any LED activity on unibox when you press "Unlock" button ? Green LED have to blink very fast after you press "Unlock" button. 3. Give me Log file or text from Log window. This can helps to solve your problem. You can get more information about this here: http://forum.gsmhosting.com/vbb/showthread.php?t=200078 | |
08-04-2005, 19:53 | #6 (permalink) | |
Member: 39250 Status: Offline Thanks Meter: 64 | Quote:
i try without external power for cable and now i don't have Phone i delete all Logs fot E101 ...!! ReGards Faisal !! | |
08-04-2005, 19:58 | #7 (permalink) |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | I have to squeze the cable in very hard for the whole time during unlocking, once I had to take phone apart and bend pins, I think the cable is about 1/2mm to short |
08-04-2005, 21:17 | #8 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | I don't know why u peoples have too many problems Just use ur COM1 Comport & G50 Cable ( Cable Point Completey IN the Phone ) You can connect the Phone on 1 SHOT . Its the same way like u connect ur X300 , G50 etc . |
08-27-2005, 18:26 | #13 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | ur problem is driver make u used ur infinity with universal box ,i have same exprience,just used ur cable ith uni box |
now vodafone228fm by zte with counter blocked unlock ok with infinity | genci titi 2002 | Infinity-Box | 2 | 01-19-2009 13:44 |
can't unlock w230 with Rocker.Dongle but well unlocked with smartclip | ROMAB | Rocker Dongle (By Legija) | 9 | 12-30-2008 13:28 |
can't unlock z320 using infinity pl | ruvanw1979 | Infinity-Box | 8 | 10-03-2008 13:25 |
((( why i can't connect J100 with infinity ))) | Faisal_Computer | Infinity-Box | 10 | 04-30-2007 10:04 |
i Can't Unlock G51E with Infinity Box | flechazo | Infinity-Box | 1 | 07-09-2005 14:47 |
