09-18-2005, 06:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | To all : Solution for "Priviliged instruction" ... http://www.sws-redbox.net/members/pa...tup_NTport.rar PS : you need administrative right to run the installation program, but after the reboot, any normal users can use REdbox exe. |
09-18-2005, 21:54 | #3 (permalink) |
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | what you not understand man ?? what i have explain are for people that got "Privilliged Instruction" when he tryed run last soft under windows Xp (NT platforme) ! if you have such thing do exactlly what i said in previous message. Regards, |
09-19-2005, 00:46 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | i did it, but still the same even after restart pc i have seen today a new file in the support, named :NT_privillege_instruction_solution.rar they are 7 files but what we have to do with?? |
09-19-2005, 01:26 | #5 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | had anyone solve the probleme "Priviliged instruction" ?? for me i used all the solution gaven even that was given by PADERF, but nothing work!!!!!! need help pleeze i can't use the last updates |
09-19-2005, 02:12 | #6 (permalink) |
No Life Poster Join Date: Sep 2002 Location: ''Inside your Brain''
Member: 15800 Status: Offline Thanks Meter: 66 | @bono_x100,bro clean up your system or format your pc.for me no need cozz all sws software is running smotly but my pc is newly formated.. BR Spun |
09-19-2005, 12:27 | #8 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Dubai
Member: 45561 Status: Offline Thanks Meter: 59 | Can not work using the instruction by PADERF "Privilliged Instruction" please i do want to know weather ant person have xp runing the last update cause everone can not do anythimng with the last update |
09-19-2005, 14:35 | #10 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Lisbon, Portugal Age: 47
Member: 69293 Status: Offline Thanks Meter: 19 | For Windows NT/2000/XP When you install your application to a Windows NT/2000/XP system, you have two choices: 1) If all the users have administrative rights, you can install ntport.dll and zntport.sys to Windows\System32 directory. In this case, you need not do any other configuration. 2) If some users don't have administrative rights, you need to create an installation program to install the NTPort Library driver. The installation program should do following steps: - Install ntport.dll to WinNT\System32 directory - Install zntport.sys to WinNT\System32\drivers directory - Import the registry settings from ntport2.reg - this file is in the ntport directory - Restart Windows |
09-19-2005, 15:49 | #11 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
what's happened, i think that no one have runed this probrames with xp no? | |
09-19-2005, 15:56 | #12 (permalink) | |
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | Quote:
Regards, | |
09-19-2005, 16:03 | #13 (permalink) | |
09-20-2005, 11:18 | #14 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | and i am having problems too to run this program it is using 100% of cpu and freezes the computer i have tryed on dell pentium3 1 ghz, 256 mb and sempron 2800+ with 512 mb ram in both cases it uses 100% of cpu and freezes computer br |
To All final solution for unlock phone Contact Retailr | zakryia | Nokia Base Band 5 ( BB-5 ) | 36 | 04-14-2009 18:53 |
Hi to All :-) twoo alcatel dead bf3 and bf4 read all phone ok !!!but not written | CHATAR | BF, BG, TH, BHx Series | 9 | 09-02-2002 22:59 |
To All! Real solution for Unlock J70 (Telefonica MoviStar) | sed_alex | Sony | 0 | 08-14-2002 17:25 |
TO ALL : IMPORTANT CHANGEMENT ON GSM-SOURCE.COM | source | GSM Mobile Links | 12 | 09-06-2001 11:16 |
