Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 09-20-2005, 16:52   #1 (permalink)
Member: 96525
Sharp GX10i unlock problem
I have a Sharp GX10i phone which had software problems.
I entered Manual Diag mode and i formatted user area.
After that phone became SIM locked.
I tried to unlock with cable solution, phone doesn't unlcok with none of tested soft.
It enters backup mode, but cannot restore.
Any idea how to unlock?
I tried even with GX15 soft, because in diag mode phone says:
GX15 diag version. 2002. 10. 03 v24
I also tried to unlock with SPST for Vodafone Version 1.17
I used function "Default Set"
Everything completes OK, but phone still locked.
Old 09-20-2005, 18:04   #2 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
Here is Ur solution
http://www.mobilewala.com/forum/show...?p=120#post120
Kuku
Old 09-22-2005, 08:28   #3 (permalink)
Member: 96525
Thank You very much, Kuku, but i still have problems.
I had this soft, but doen't connect to my phone.
I have USB cable, and i think that soft works only on COM1. Is that right, or can i change the settings to other COM?
My USB cable converts to COM4.
For trying the soft, i disabled COM1 and COM2 on the motherboard and set the USB cable to convert to COM1.
Soft stil doesn't connect to switched on phone.
SPST connects, but doesn't unlock my phone.
Any ideas?
Old 09-22-2005, 08:51   #4 (permalink)
Member: 96525
Thank You, Kuku, i solved the problem, i changed to another powered USB port and worked OK.
Thanks again
Old 09-23-2005, 16:27   #5 (permalink)
Member: 172227
Thanks Meter: 19
Cool
http://www.unlockeasy.com/modules.ph...titleA&show=10
Old 09-23-2005, 17:18   #6 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
Hi Here is Sharp GX10 & GX10 i Unlocking Solution
Gx10i/Gx10 security code
for all who have problems works 1000%
full factory reset - clears EVERYTHING
Remove SIM
1 Press 0, 3, top right key and Red key together for about 3 secs until a white display is shown.
2 Press 0, 1, 2, 3, top right key, 1, in sequence. The Diagnosis menu should be displayed.
3 Enter 99 and press the top right key. A message should be displayed saying Input Mode No:
4 Enter 1 and press the top right key. The following messages should appear:
· EE_FORMAT START
· EE_FORMAT OK
· EE_INIT(1) START
· EE_INIT(1) OK
· BBSRAM CLEAR END
· FINISHED
· PLEASE ANY KEY
5 Wait until all the above messages are displayed and then press the top right key.
6 Press the M key (very important). Message should display Diag Param Saving.
7 Press the red key to power down the phone
Again many thanks to ''unlockchips.com' from nokiafree.org - thought I was knackered cos charger connector block
after when u insert sim u will see .....invalid sim card
so unlock it with.
http://forum.gsmhosting.com/vbb/sho...24&postcount=27
br
Rocky
Old 10-06-2005, 01:22   #7 (permalink)
Member: 66841
I need cable drivers USB for gx10i [email protected]
Old 02-13-2006, 23:09   #8 (permalink)
Member: 16830
Thanks Meter: 32
Remove SIM
· EE_FORMAT START
· EE_FORMAT OK
· EE_INIT(1) START
· EE_INIT(1) OK
· BBSRAM CLEAR END
· FINISHED
· PLEASE ANY KEY
so unlock it with.
br
Rocky
thanks man very much! works for me 10000%.
Old 03-24-2006, 16:21   #9 (permalink)
Member: 248962
hi can anyone give or email me a link for the software i need unlock my sharp gx10i i have a usb to phone and all the links on here will not open
this is doin my head in SOMEONE PLZ HELP
thanx
sezy
Old 09-18-2006, 15:01   #10 (permalink)
naeem janjua's Avatar
Member: 155992
Sonork: 1585672
Thanks Meter: 171
Smile
good work bro it really works. thanks.
Remove SIM
· EE_FORMAT START
· EE_FORMAT OK
· EE_INIT(1) START
· EE_INIT(1) OK
· BBSRAM CLEAR END
· FINISHED
· PLEASE ANY KEY
so unlock it with.
br
Rocky
Old 11-03-2006, 04:57   #11 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 118
I know this is an old thread but, i was forced to write a post to request the soft to unlock invalid sim in gx10, coz i found that all link is dead. But i'll try to search more. Thanks
br,
s1emens
Old 11-09-2006, 12:52   #12 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
yes, me too have same problem!
Old 11-10-2006, 00:25   #13 (permalink)
Member: 147907
Thanks Meter: 9
Go here and download the program by All-Katel.
Old 11-10-2006, 04:32   #14 (permalink)
BENCHENA's Avatar
Member: 116657
Thanks Meter: 56
hi
you should better use com cable it work fine & no problem
Old 02-20-2008, 16:03   #15 (permalink)
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
com cable needs no stress but usb u have to modify some configurations in device manager
SHARP GX10i unlocking problem, HELP !! pmauricio Sharp 1 06-08-2006 14:34
Sharp GX10i flashing problem - FreaX ? Patrick Sharp 4 09-16-2005 14:41
sharp gx10i network problem atfer unlock karamusa Sharp 11 04-01-2005 11:25
sharp gx10i charging problem karamusa Sharp 2 04-17-2004 15:57
Sharp gx10i unlocking software stukachu Wanted Products 3 08-06-2003 15:51
Page generated in 0.31638 seconds with 9 queries
