Member: 167856
Thanks Meter: 4 | Samsung User Guide & Description Samsung Astro-Clip User Guide & Description. Cable type and compatible models:- Samsung D500 cable: - (D500, D500E, E730, E350, E340, E340E,E760 D600, D600E).
- Samsung Sxxx cable: - (S100, S105, P777).
- Samsung E810/E720 cable: - (E810, P720, P735, E720, S341i, S342i, D428).
- Samsung E700 cable: - (D488, E330, E630, E638, E700, E708 E800, E808, E820, S500, S508, X100, X108, X460,
X468, X600, X608, X640, X495, X497).
- Samsung V200 cable: - (D100, D410, D415, D418, D710, E105, E108, E300, E310, E318, E400, E600, E608, E610,
E710, E715, E718, E850, P100, P108,
P400, P408, P710, S200, S208, S300, S300m, S308, V100, V200, V205, V208, X105, X120, X400, X426, X427, X430,
X438, X450, X458, X610, X710).
- Samsung A/C/N/R/T-series cable: - (C100, C108, C110, P510, P518, Rxxx, Nxxx, Axxx, Txxx).
- Samsung E530 cable: - (E530).
=========================================== Unlock solution for Red marked phones: - Connect 9V battery to the clip.
- Power OFF your phone.
- Connect Cable to the clip - Do not connect phone yet.
- Press unlock button in the clip (led will goes Red) and hold it until led goes Green and Red again.
- Connect phone to the cable.
(If led will not goes green in a few seconds then press power ON button in your phone and hold it until led goes green). - Wait until led will blinks a few times.
=========================================== Unlock solution for Yellow marked phones: - Connect 9V battery to the clip.
- Connect Phone to the clip via D500 cable.
- Press power ON in your phone and hold it until led goes Green
=========================================== Unlock solution for White marked phones: - Connect 9V battery to the clip.
- Connect Phone to the clip via right cable.
- Press shortly unlock button in the clip.
- If led goes Red press power ON in your phone and hold it until led goes Green - If led goes Green just wait.
=========================================== Unlock solution for Green marked phones: - Connect 9V battery to the clip.
- Connect Phone to the clip via E700 cable.
- Press unlock button in the clip (led will goes Red).
- Press power ON in your phone and hold it until led goes Green.
- Now your NCK code is “00000000” (8 zeros) - You must enter it manually via entering #7465625*638*00000000#.
=========================================== Unlock solution for P207 Phone: - Install Samsung USB Driver
- Run Update Software For Clip
- Connect Clip to PC Via Update Cable.
- Press unlock button in the clip (Untill led will go from Red to Green)
- Click (Direct Unlocker)
- Connect Phone to PC Via P207 Usb Cable.
- Check In system , What is your Virtual Comport for your Samsung phone.
- Choose this Comport Number in your Virtual Comport.
- Click (Unlock P207) Button .[/I]
With the best regards, AstroTeam www.astro-clip.net |
