11-11-2005, 19:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2001
Member: 3279 Status: Offline Thanks Meter: 19 | USB Smart Z / V800 error , phone dead Phone KEY: A1_DB2000_36_RED OTP CID: 36 Phone IMEI: 35488500645793 Flash ID: 890D Switch phone ON Send FLASH application Send MAIN flash file: "Z800_R1AB013_EAL_ZONE1_STANDARD_IMEI.mbn" MAIN flash sent OK Send FS flash file: "Z800_R1AB013_EAL_EU2.fbn" FS flash sent OK Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2000_36_RED OTP CID: 36 Phone IMEI: 3548850064XXXX Flash ID: 890D Switch phone ON Send FS application Start FS services ERROR: 303106 some help would be appreciated |
11-11-2005, 20:03 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Japan Age: 42
Member: 150697 Status: Offline Thanks Meter: 7 | dont listen to dky.. he has no idea what he is talking about. this was a problem with older SEMC TOOL.. download newest tool and recharge battery on different phone.. all will be ok. |
11-11-2005, 23:47 | #7 (permalink) |
No Life Poster Join Date: Mar 2003 Location: One step before you ;) Age: 42
Member: 23695 Status: Offline Sonork: 100.64383 Thanks Meter: 12 | ERROR: 303106: You have different flash files versions…Correct this little mistake and try again --------------- ERROR: 30353B: You have tried to flash the three flash files (Main, Fs, Sfa). Flash only= TWO flash files and later if you want you can flash Sfa file in the phone only. --------------- ERROR: 300314: This Error is appears when you have a V600(maybe any phone) with CID’s mismatch. Flash Erom with CID36 from support area for that phone. Also as a suggestion flash with main and fs file after Erom for better result. --------------- ERROR: 003608, ERROR: 00360C & ERROR: 00360C: This errors where showed when the phone had the RSA killed by Twister or Terminator --------------- ERROR: 304314: This error appears when you are using flash files with CID lower than in OTP. You must use equal or higher. --------------- ERROR: 0001A1: Possibly problem due to cable with bad connection. Check the cable or buy a new one --------------- ERROR: 00A405: This problem happens when you have communication/timers problem check that the cable is working and post a thread telling the exactly error if still happening. Problem related to T100. It’s impossible to clear SP locks in this phone. --------------- ERROR: 300301: Bug found in v1.1 in Sony Ericsson z1010, support with CID16. Problem already solved --------------- ERROR: 304107 & ERROR: 304106: Recover Certificate Problems --------------- ERROR: 303002: This problem appeared when you are trying to Complete the phone alter flash. This error should be already solved. Occurred in v1.7 --------------- ERROR: 304100: This error appears when we are trying to flash a phone that’s empty. This will be solved in a short period of time. In Z1010 phones with CID16 we had this bug corrected already in v1.9 --------------- ERROR: 302403: This was a bug corrected in v3.1 so if you have seen this error download last exe. Also this error appeared in v2.0 reading flash files bug was fixed --------------- ERROR: 300314: Problem when trying to unlock V600 in v1.7/1.9 fixed on newer versions. --------------- ERROR: 003612: Use another cable T28 com cable doesn’t work in AVR phones --------------- ERROR NETWORK CONTACT: You have to Complete phone --------------- |
11-12-2005, 00:00 | #9 (permalink) |
Member: 23695 Status: Offline Sonork: 100.64383 Thanks Meter: 12 | i think 303105 same with 303106 or the program have communications with the marita chip try with lower baudrate or older exe about 300392 i dont know its zulea mistake br shaaker |
11-12-2005, 00:06 | #10 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Bosnia and Herzegovina RS Age: 53
Member: 94109 Status: Offline Thanks Meter: 0 | Quote:
Regards, ECS. | |
11-12-2005, 13:40 | #12 (permalink) |
Junior Member Join Date: Dec 2004
Member: 100206 Status: Offline Thanks Meter: 0 | I've have the same problem as ahmed, but I don't have access to the older SEMC_Tool files (just bought my usb-smart, so I only have dl v5.0 & 5.1) Is there anyone who can send me an older version that works ok on z/v800 (4.1), or can tell me were I can download it.. Thanx in advance /Jonas |
11-13-2005, 13:51 | #13 (permalink) |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | @shaaker do you have the complete ERROR CODES for USB SMART, sir? can u post it here or upload it at the SUPPORT SITE for USB SMART? THANK YOU VERY MUCH SIR |
usb smart free support error | celluniversal | Sony Ericsson | 2 | 02-06-2007 19:41 |
help usb smart not recognized ERROR | hussaingreat1 | Dongle Problems (USB-Smart) | 2 | 03-27-2006 13:04 |
USB-Smart read ID ERROR on AMD64 | jcmerg | SonyEricsson (USB-Smart) | 36 | 01-07-2006 19:17 |
Solved first problem, think usb-smart can´t complete phone right?! | phone_abuser | SonyEricsson (USB-Smart) | 3 | 11-14-2005 23:47 |
