12-22-2005, 00:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Lithuania,Kaunas Age: 48
Member: 33166 Status: Offline Thanks Meter: 4 | Problem unlock VS2 Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356801007793004 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.02SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS2-VF10,Oct18200502:20:47 In progress[EEP01_356801007793004]... In progress[EEP02_356801007793004]... Found: Network Err: unlock not possible[01] Done Finished Where is problem? I can read flash if needed and send to infinity team. |
12-22-2005, 22:14 | #5 (permalink) |
Member: 33166 Status: Offline Thanks Meter: 4 | Thank you very much, with you help now VS2 unlocked. Log: Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356801007793004 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.02SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS2-VF10,Oct18200502:20:47 In progress[EEP01_356801007793004]... In progress[EEP02_356801007793004]... Found: Network Unlock code: 25813568 EXACTLY STEP-BY-STEP: 1. insert ANY sim-card into phone 2. switch-on phone 3. switch-off phone 4. switch-on phone, press 52824** 5. enter unlock code 6. switch-off phone Done Finished Infinity team is the best!!!!!!!!! |
03-25-2006, 21:31 | #6 (permalink) | |
Insane Poster Join Date: Dec 2001 Location: UK
Member: 7857 Status: Offline Thanks Meter: 1 | Quote:
03-26-2006, 06:24 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, If software show you code and unlock instruction this means that this phone supported. After you enter last * you have to see sim-lock menu on phone LCD. if you don't se sim-lock menu make unlock procedure again. Use ordianary sim-card, no need to use any kind of test-cards. Use always only one sim-card (no need to use different sim-cards during unlock process). |
03-26-2006, 10:47 | #9 (permalink) | |
10-19-2006, 21:20 | #10 (permalink) |
No Life Poster Join Date: Jun 2002 Location: *Portugal* Lisbon* Age: 45
Member: 13223 Status: Offline Thanks Meter: 59 | vs3 don´t have unlock menu , i have flash version v08 , v10 , a47 same thing read unlock code but when i press 52824** don´t make nothing ,. Any sugestion ? Thank you . B.R Nokall |
10-20-2006, 09:03 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no any other suggestion. Only my old suggestion: make unlock process again after unlock process finished: make all steps like described in software log window exactly. |
10-20-2006, 19:17 | #14 (permalink) |
Member: 7857 Status: Offline Thanks Meter: 1 | To show the sim-lock menu you have to enter the code with a sim card in the phone from the network that the phone was originally locked too. So if the phone was locked to Vodafone, put a Vodafone sim in and enter the code. After you have entered the last * the sim lock menu will appear. |
pls help - FGold to unlock Vs2 | ktele | FuriousGold | 3 | 11-02-2007 15:53 |
BIG problem unlocking a 6131 !!! HUGE PROBLEM !!! | humbedj | UID - Box | 9 | 10-13-2007 00:20 |
how to unlock vs2 | yoda67 | Panasonic | 3 | 11-24-2006 23:33 |
Help unlock VS2 | 5aaaaa | Redbox | 1 | 05-20-2006 08:54 |
wow unlock vs2 and vs3 perfectly | falak | Infinity-Box | 0 | 01-10-2006 07:13 |
