03-15-2006, 11:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239119 Status: Offline Thanks Meter: 9 | cant flash w550 with enternal batt 9v error Code: McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1250165_050909_1014_R2A{DB2010_CID49_RED}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT FlashImage: X_W550_CXC1250087_CHINA_EL_R4AB048_RED49.bin (49_RED) FlashImage Certificate Accepted Flashing Error 2: Timeout, 0x7000 MCU Part_1 Flashing Failed, Time: 00:38 |
03-15-2006, 12:00 | #2 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | cant flash cust/fs Code: McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1326739_R2F{0101030301}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 040614 1538 LLECXC1326739_COMPACTCERTLOADER R2F, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 009283023C436921 - Locked OTP_U: 218042740560B9B8 - Locked 050913 1438 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3G ITP Sw : Brand : Generic Trade CUST Lp: CHINESE CDA ver: CDA102415/31 R7A CXC ver: cxc1250032 R4AB048 Initialization Err_08.2: Bad Resp Hdr 06, |
03-15-2006, 12:17 | #3 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | when press info Code: McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1326739_R2F{0101030301}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 040614 1538 LLECXC1326739_COMPACTCERTLOADER R2F, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 009283023C436921 - Locked OTP_U: 218042740560B9B8 - Locked 050913 1438 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3G ITP Sw : Brand : Generic Trade CUST Lp: CHINESE CDA ver: CDA102415/31 R7A CXC ver: cxc1250032 R4AB048 CustBundle: X_W550_CDA102415-31_CHINESE_R1A.bib CUST Flashing Done, Time: 03:28 McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1250165_050909_1014_R2A{DB2010_CID49_RED}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT Resp Ln: 1, 027C010000000000, Retrying nACK , 1500000000000000, Retrying No Resp, 0000000000000000, Retrying No Resp, 0000000000000000, Retrying Rd_Error at: 0x45EFFFF4, 0000000000000000 INFO Error 1 Configuration Err_40: No Resp User Stop, Total Time: 10:57 |
03-15-2006, 12:49 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | You need to use Test Point to flash Cust/FS at the moment with KZF, your phone will not work correct until this has been done, check this thread for advise and solution:- http:///vbb/showthread.php?t=260070 Odia. |
03-15-2006, 14:42 | #5 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | i always flash with tp. all is ok,but no network and keypad just can press 1.3.5.7.9.0 and no light why can be like this? or flash wrong flash file or flash wrong gdfs flash file? b coz i flash the gdfs file. but dunno right or wrong....!!!!!!!!!!!!!!!!!(no have hwk gdfs file) please help...! all is ok but keypad and network problem |
03-15-2006, 14:55 | #6 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | flash with this file FlashImage: X_W550_CXC1250032_CHINESE_R4AB048_RED49.bin (49_RED) X_W550_CXC1250032_CHINESE_R4AB048_RED49.bin X_W550_CDA102415-31_CHINESE_R1A.bib |
The Following User Says Thank You to gct For This Useful Post: |
03-15-2006, 15:02 | #7 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | now flash with this step Code: All step wise procedure here...its been tested by me working 1000000000000000000% with crack hwk...so think it should work with OG 1 open your handset take out two wires one from test point and one from ground 2 close your handset without screw 3 connect your handset with full charge battery 4 select bypass to tp 5 now flash both mcu files one bye one it will ask for connect test point just DONT connet wiren and press ok later it will ask disconnect tp again just press ok 6 same way flash both mcu files provided with hwk 7 then select FS this time yhou have to connect both wires when it ask connect test point and disconnect later 8 finaly dont forget to int sb with connecting both wires when it ask connect test point same have been discussed so many times in this great forum but still some peoples not getting it hope this help them ALL Credit goes to GSM RAJ Thanx & Regards |
03-15-2006, 15:27 | #8 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | Code: McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 X_W550_CDA102415-31_CHINESE_R1A.bib [Cust Bundle] Trying: CXC1326739_R2F{0101030301}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 040614 1538 LLECXC1326739_COMPACTCERTLOADER R2F, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 009283023C436921 - Locked OTP_U: 218042740560B9B8 - Locked 050913 1438 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3G ITP Sw : Brand : Generic Trade CUST Lp: CHINESE CDA ver: CDA102415/31 R7A CXC ver: cxc1250032 R4AB048 CustBundle: X_W550_CDA102415-31_CHINESE_R1A.bib CUST Flashing Done, Time: 03:32 McuId: 80400301FFFFFF, CID: 49, 4 (Red) Mcert: A1_DB2010_49_RED Baud Rate: 921600 Trying: CXC1326739_R2F{0101030301}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 040614 1538 LLECXC1326739_COMPACTCERTLOADER R2F, Ok IMEI : 135744-20-075663-0, CID: 49, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 009283023C436921 - Locked OTP_U: 218042740560B9B8 - Locked BLK_0: 0x45F00000 IMEI : 135744-20-075663-0 OTP CID: 49, GDFS CID: 49 ULCK : 0000 - Off NCK : Open [5-5] 246-01 NSCK : Open [5-5] 246-01 SPCK : Open [5-5] 246-01 CCK : Open [5-5] 246-01 PCK : Open [5-5] 246-01 ESLK : Open [5-5] FFF-FF Flags : 0AFFFFFFFFFFFFFFFFFF [EGSM900,DCS1800,PCS1900] Security Backup: W550_135744200756630_3152006_102148.sim Security Initialization Done, Time: 00:22 User Stop, Total Time: 04:19 same no network,keypad just can press 1.3.5.7.9.0 why? |
03-15-2006, 15:49 | #11 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | when press info ,always write this Code: nACK , 1500000000000000, Retrying No Resp, 0000000000000000, Retrying No Resp, 0000000000000000, Retrying Rd_Error at: 0x45EFFFF4, 0000000000000000 INFO Error 1 Configuration Err_40: No Resp |
03-15-2006, 15:53 | #12 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Was this phone empty board? If not why did you flash GDFS? Try to restore the oldest .sim backup for this phone and see if that brings the network back. Odia. |
03-15-2006, 16:00 | #13 (permalink) |
Member: 239119 Status: Offline Thanks Meter: 9 | i din have any oldest.sim, b coz first time i flash i have been flash the gdfs . sorry,b coz i dun no have to flash no body teach me. after do with myself ,have problem. find at website,i flash wrong step... ---------------------------------------------------- and what wrong with keypad ? just can press 1.3.5.7.9.0 what can i do now? |
w550 cant flash "configuration error" | Javajohn | GOT SEMC | 0 | 01-21-2007 18:53 |
w550 dead cant flash | alhamde16 | Cruiser Suite | 2 | 01-15-2007 19:43 |
Problem while flashing W550.... | drag | Cruiser Suite | 46 | 12-19-2005 13:15 |
i will try for flashed w550 with cruiser but cant attached | gsm4libya | Cruiser Suite | 0 | 12-12-2005 16:06 |
How to flash w550? | sim1 | Cruiser Suite | 1 | 11-25-2005 13:12 |
