06-03-2006, 12:25 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | 03.06.06 - SagemDD V4.1 & V4.2 was released Version 4.1 of SagemDD was developed for discovering "Bootloader failed" error causative by "too long TP wires". When you use V4.1 and get "PROBLEM:Bad log! Is your box cable shortened?" message from server, this indicates that total cables lengths are too long and must be shortened. If phone (Hash Table) are supported stand alone, same error message - "PROBLEM:Bad log! Is your box cable shortened?" will appear directly from SagemDD software! Simple solution is: Total length of the cable between RJ45 (box) and RJ45 (TP adapter) must be less than 30cm. We recommend you cable shortening to the limit on box side. What to do: Open connection-block and write down position and color of each wire coming from box and joined to connection-PCB. Now cut the cable to total length no more then 10cm. and solder back wires to connection-PCB using position and color from notes. We will report cables manufactures to do this changes in production stage yet! SagemJtagUnlocker Team 5.06.06 SagemDD_V4.2 released. Fixed bug about cable diagnostic for some M62+ phones! Last edited by latigido; 06-06-2006 at 07:28. |
The Following 5 Users Say Thank You to Oxo_Boxo For This Useful Post: |
06-03-2006, 15:24 | #11 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
But dear We Get Standard cables with Box when we Purchase SagDD. So why it Show Such error. or u r talkin about repaired Cable ? BR. | |
06-03-2006, 15:31 | #12 (permalink) | |
From Box Female RJ45 to Jig or TP Adopter Female RJ45 Cable Must be 10 cm to less then 30Cm not more then that. BR. | |
06-03-2006, 16:02 | #13 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | Quote:
Less than 5% of customers get this error/message with some Sagem phones. See our old recommendations about cables (www.sagdd.net) and compare with your so called "standard" cable. | |
06-03-2006, 17:41 | #14 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 51
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | never had any problem with that....i use original cable......... But once again....very good support best regards |
sagemdd v4.2 was released | sabeurtoufik | SAGEM JTAG UNLOCKER | 0 | 06-10-2006 11:51 |
SagemDD V4.2 was released | NadeemShahzad | SAGEM JTAG UNLOCKER | 3 | 06-07-2006 02:58 |
UN LOCK NOKIA 3330 v4.30 & v4.50 without downgrading "2" | majid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 12-18-2001 22:26 |
UN LOCK NOKIA 3330 v4.30 & v4.50 without downgrading | Mehvishal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-16-2001 23:23 |
Looking for unlocking flash for 3330 v4.30 & v4.18 | enric666 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-01-2001 03:34 |
