09-27-2006, 15:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | C117 Phone is Hacked.. UNLOCK Code: Log opened: [9/27/2006] [7:00:56 PM] App: C:\Program Files\InfinityBox\Moto01_v116\Moto01.exe [Infinity Box] v.1.16A Loading, wait... S/N: 0A8A:0108 Standard firmware detected Current device: C113,C115,C116,C117,C118 Ready COM1 selected Action: Unlock Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW Ver: 2.5.78.N. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... File saved: Backup_eeprom-1__2006-9-27_19-1-41.18E.bin Check Flash-2 Done Write... Write Done Finished Remove/Install battery now ! Time used: 48 sec Code: Log opened: [9/27/2006] [7:08:39 PM] App: C:\Program Files\InfinityBox\Moto01_v116\Moto01.exe [Infinity Box] v.1.16A Loading, wait... S/N: 0A8A:0108 Standard firmware detected Current device: C113,C115,C116,C117,C118 Ready COM1 selected Action: Format Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW Ver: 2.5.78.N. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Write Done Finished Remove/Install battery now ! Time used: 25 sec i do this two step but not result here is backup file if its help.. |
09-27-2006, 16:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Pls, make this: 1. make full flash backup 2. send full flash backup to [email protected] 3. flash phone with any 1.x.x firmware from support area |
09-27-2006, 17:16 | #4 (permalink) | |
Member: 50805 Status: Offline Thanks Meter: 101 | Quote:
i try to flash but not with 1.x.x i try it to flash it with 2.x.x this error comes i try with 1.x.x. and post result again COM1 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Err: boot[04] Release Power button ! Connect Fail Finished Remove/Install battery now ! Time used: 9 sec this is with 2.x.x | |
09-27-2006, 23:56 | #5 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | Quote:
P.S: what about "Latency Timer" is the value set to 4 (check your Documentation folder ) but about your main problem i think you need special flex wait mr InfinitySupport he ''ll do his best for sure | |
09-28-2006, 02:00 | #6 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 42
Member: 70573 Status: Offline Thanks Meter: 24 | I have same Proplem with C118 after unlock phone is OK, Flash with other Firmware ----> Phone is dead----> try with other firmware ---> Err: boot[04] Fix by original cable include box of phone( SKN6233A, USB to COM)!!!!!! ---->Full flash with this cable -----> phone is OK. Good Luck! |
09-28-2006, 04:42 | #7 (permalink) |
Freak Poster Join Date: Jan 2005 Location: india
Member: 102598 Status: Offline Thanks Meter: 68 | 1. Open phone and GENTLY cut track according to picture NOTE !!! Track have to be restored after repair procedure, so, cut track very gently and be sure that you can restore track back after repair process. 2. Start "Repair Module" software 3. Load "Repair data" file 4. Press phone "Power" button and wait until process finished (about 1 min) 5. Now phone repaired, but can't power-on 6. Restore track back 7. To make phone completely repaired you need to flash phone (Main+Flex+LP) tested by me 1000% work |
09-28-2006, 08:30 | #8 (permalink) | |
And "RepairModule" can helps with any firmware version. After writing firmware 1.x.x phone must be alive even after "phone is hacked" message. | |
09-29-2006, 07:15 | #9 (permalink) | |
yes phone is still alive and display "phone hacked msg" and i m using Serial Com cable so not need to set "Latency Timer" not able to flash phone everytime it shows error | |
09-29-2006, 09:23 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
09-29-2006, 10:17 | #11 (permalink) |
No Life Poster Join Date: Dec 2002 Location: cell-spare cochin penta kerala
Member: 18837 Status: Offline Sonork: 100.1601544 Thanks Meter: 71 | Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 2.5.78.N. HW ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-9-29_14-24-19.18E.bin Check Flash-2 Done Write... Write Done Finished Remove/Install battery now ! Time used: 18 sec another c117 after unlocking with infinity "phone hacked" |
09-29-2006, 11:31 | #13 (permalink) |
Member: 18837 Status: Offline Sonork: 100.1601544 Thanks Meter: 71 | Loading... C115_1.0.38_Main.18M.bin Loaded Loading... C115_1.0.38_Flex_03_132.18F.bin Loaded Loading... C115_1.0.38_LP_T14_132.18P.bin Loaded Write: Firmware Write: Flex Write: Language Pack Device: C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... Set Baud Done Check Flash-1... SW Ver: 2.5.78.N. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: all flash areas Write Done Finished Remove/Install battery now ! Time used: 310 sec its working perfectly now.my phone has been unlocked perfectly with infinity.many thax to infinity team. am ride out from phone hacked of c117 |
09-29-2006, 17:14 | #14 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Ukraine,Simferopol Age: 48
Member: 16251 Status: Offline Thanks Meter: 38 | man - about this procedure many peoples tell to you many times ! why you understand only after support team write specially for you this doc? all is simply man!!! just use your brain - nothing else and nothing impossible! |
09-29-2006, 17:31 | #15 (permalink) | |
Member: 18837 Status: Offline Sonork: 100.1601544 Thanks Meter: 71 | Quote:
i did not seen any post before speciay for c117. can u show me that tred which is usefull for c117?. what i did its helpfull for other infinity users. u can see one person having this same problem on this same thred.this thred started by him only. one more thing................. if the team write specialy for me then whts the problem? i also purchased this box from infinity team only | |
j100i phone is hacked | djpaul | Infinity-Box | 32 | 12-15-2009 18:44 |
j100 phone is hacked | fereemetal | Sony Ericsson | 4 | 07-29-2008 19:00 |
c140 phone is hacked | shripalkawdia | Infinity-Box | 25 | 05-11-2007 20:22 |
c261 phone is hacked | kulvindersingh | Infinity-Box | 3 | 03-14-2007 19:04 |
c117 phone is hacked | ..:MumbaiGsm:.. | Infinity-Box | 2 | 01-30-2007 10:11 |
