Old 12-02-2006, 15:35   #1 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
((( Lock Code X700 Removed luv Infinity )))
Superb Infinity box Is able to Unlock Lock code on X700 ....Not possible anywhere else....(as Much i searched)
Select eeprom from support (only one available)
Select Reset to Defaults
Flash EEPROM as Firmware Main (when selecting file underTAB select Allfiles)
After Done Power On ur phone and Give a Kiss to This Infinity BOX
Thankx Again.....Long Live Infinity Team ......
The Following User Says Thank You to Amir-SkillZ For This Useful Post:
Old 12-02-2006, 22:57   #2 (permalink)
Member: 166086
Thanks Meter: 9
Not work for me. Invalid sim card
Old 12-02-2006, 23:08   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
possible reasons:
1. Your phone has sp-lock, not user code
2. Your sim card not accepted by network (not by phone)
Old 12-03-2006, 06:00   #4 (permalink)
Member: 91045
Thanks Meter: 8,696
Invalid sim cardThats SP Locked Mate
Try Unlocking Simply Must work for Sure
Old 12-03-2006, 06:40   #5 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
lock code done 4 longs on infinity box ....greaat box
Old 12-12-2006, 11:44   #6 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
some clarifications.
original X700 USB cable must by used (or should the x70 cable be used)
Should the phone be turn on and installed drivers (or should the x70 and infinity box be used)
then select port for X700 modem ?
Then Flash Eeprom file
or must the phone be in some form of test mode when installing the EEprom file ?
Old 12-12-2006, 11:58   #7 (permalink)
Member: 130995
X70 cable should be used, phone should be power-off, no need to use any drivers.
Old 12-13-2006, 11:13   #8 (permalink)
Member: 300911
Thanks Meter: 3
not 1 kiss 1000 kiss for u for x700 soluotion .
thanx very very much
Old 12-13-2006, 12:49   #9 (permalink)
Member: 187451
Thanks Meter: 163
Infinity do 100%
1=sp unlcoking
2=repair Eprom
3=reset user lock.
and i tested all that.
One kiss from my team to the infinity team.lol
Old 12-13-2006, 13:26   #10 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
its real worth for my money....i gained money infinite times...by using INFINITY BOX..
THNKS TO INFINITY TEAM..
Old 08-29-2007, 10:34   #11 (permalink)
serkan45's Avatar
Member: 159363
Thanks Meter: 21
* # power pressed result nonexistent
Old 08-29-2007, 10:47   #12 (permalink)
Member: 130995
if you want to make unlock you must read documentation.
D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_X700_X701
If you want to clear user code you must read first message in this thread.
Don't be lazy, read before ask !
Old 08-29-2007, 15:08   #13 (permalink)
Member: 20069
Thanks Meter: 131
thanks for posting tested results n also thanks to infinity team for their hardwork.
kiss to infinity box.
Old 02-20-2009, 17:23   #14 (permalink)
Member: 61039
Thanks Meter: 67
To InfinitySupport:
This method exactly worker at presence Pana01_1.62 è eeprom:
X700_eeprom_static_03.30E.bin,
X700_eeprom_static_04.30E.bin,
X700_eeprom_static_05.30E.bin ?
Flash EEPROM as EEPROM that does not work ...
Flash EEPROM as Firmware ?
T919 need help for personal lock code to remove mymiela0419 UST Pro II 10 07-02-2009 06:03
i550w lock code not remove farshad2009 Samsung Flashers, Software, Firmware. 0 10-21-2008 14:26
x700 user lock can be removed? Raklm Infinity-Box 3 03-14-2007 14:11
Pana x700 phone lock code Alex8392003 Panasonic 10 12-14-2005 16:32
HELP!!! Forgot lock code X700... ProKakashi Panasonic 8 08-18-2005 06:39
Page generated in 0.23066 seconds with 10 queries
