03-18-2007, 00:59 | #1 (permalink) |
Product Supporter Join Date: May 2002 Age: 54
Member: 12088 Status: Offline Thanks Meter: 4 | C552 and ELLE from Latin America Solved! It is a hardware problem an need new adapter. Also need some small adaptation of C55x/Elle cable pins. I attached schematic of new adapter with connection colored like colors of wires that are using in cables. http://www.gsmmasters.com/Elle/C551-...al_Working.pdf http://www.gsmmasters.com/Elle/C55x-...ins_higher.pdf Adapter and pin adaptation tested with Elle and C552 from Movistar that WynSoft send us, thanks again WynSoft. In some situation pooling up pins will help without need of adapter. Do not forget to to download otuf214b.rar All Best Last edited by gsmmasters; 03-18-2007 at 01:11. |
03-20-2007, 19:23 | #3 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 232516 Status: Offline Thanks Meter: 2 | hi guys problems in again in C552 HI GSMMASTERS MY PROBLEM IS WHEN I USE THE VERSION 211 FOR C552 THE SOFTWARE SAID PHONE DETECTED THEN WAITING RESPOND ERROR COMUNICATION ERROR OK I WAS HAPPY WHEN I SAW THE LATEST VERSION 214B THE PROBLEM NOW THE SOFTWARE DOES NOT EVEN DETECT THE PHONE WHAT IS WRITING IS Starting boot procedure... Waiting response... Error while connecting to phone CAN U HELP PLEASE I DID POL UP THE 2 RX PINOUT I DO NOT USE THE ADAPTOR BECAUSE I DO NOT KNOW HOW TO MAKE IT SO PLEASE HELP GUYS PLEASE I LOVE MY OTUF BOX SO PLEASE MAKE PROUD OF IT THANKS GUYS |
03-21-2007, 12:43 | #4 (permalink) |
Member: 12088 Status: Offline Thanks Meter: 4 | With old version you can get message phone detected but it can not enter boot after it. In new software version some things are changed. When software can not enter boot you will not get phone detection message. However if your phone can not enter boot you must use 2.4V adapter and RxTx pins need to be higher then others. In that case works 100%. http://www.gsmmasters.com/Elle/C551-...al_Working.pdf http://www.gsmmasters.com/Elle/C55x-...ins_higher.pdf |
03-21-2007, 18:38 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: all over the world Age: 45
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | well my first c55x was done fast and without any problem Im just use box modification and pins higher http:///vbb/showpo...89&postcount=3 maybe in other phones I will need adapter anyway here is the log. txs again masters Starting boot procedure... Waiting response... Sending boot... Requesting authorization Connecting to server... Server Connected... Sending Data... Server message : Calculation Successful. Remains : 0 Authorized IMEI : xxxxxxxxxxxxxxxxxxx Version : 010 SubVersion : KY355600 ProviderID : C552A-5BTLCO1 Language pack : PY35CV60 Supported languages : EN FR PT ES Phone in boot Checking FLASH... FLASH access verified. Making tech zone backup... Tech zone backup saved Unlocking... Connecting to server... Sending log... Connecting to server... Server Connected... Sending Data... Server message : Succesfully daily add. Remains : 1 Response received... Phone is unlocked! |
03-22-2007, 03:57 | #6 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | again same procedure as I did before but this time adapter was necessary . Starting boot procedure... Waiting response... Sending boot... Requesting authorization Connecting to server... Server Connected... Sending Data... Server message : Calculation Successful. Remains : 0 Authorized IMEI : xxxxxxxxxxxxxxxx Version : 010 SubVersion : KY35B800 ProviderID : C552A-5BTLCO2 Language pack : PY35CV80 Supported languages : EN FR PT ES Phone in boot Checking FLASH... FLASH access verified. Making tech zone backup... Tech zone backup saved Unlocking... Connecting to server... Sending log... Connecting to server... Server Connected... Sending Data... Server message : Succesfully daily add. Remains : 1 Response received... Phone is unlocked! do you need more?? see elle in action. Starting boot procedure... Waiting response... Sending boot... Requesting authorization Connecting to server... Server Connected... Sending Data... Server message : Calculation Successful. Remains : 0 Authorized IMEI : xxxxxxxxxxxxxxxxxxxxxxx Version : 010 SubVersion : KY85C300 ProviderID : BL11A-5ACECO2 Language pack : PY85RA33 Supported languages : EN FR PT ES Phone in boot Checking FLASH... FLASH access verified. Making tech zone backup... Tech zone backup saved Unlocking... Connecting to server... Sending log... Connecting to server... Server Connected... Sending Data... Server message : Succesfully daily add. Remains : 0 Response received... Phone is unlocked! master wait for my dumps thread closed |
03-22-2007, 12:26 | #7 (permalink) |
Member: 232516 Status: Offline Thanks Meter: 2 | OK MR WYNASOFT1 AND GSMMASTERS PLEASE HELP ME IN MAKING ADAPTOR FOR C552 CAN U TELL ME WHERE I CAN FIND THIS ADAPTOR I MEAN RESISTOR WHAT IS IT HOW CAN I USE IT DOES ANYBODY CAN MAKE THIS ADAPTOR AND SELL IT TO ME I WILL PEY THE PRICE U NEED PLEASE CONTACT ME IN PRIVATE [email protected] THANKS GUYS |
03-23-2007, 01:29 | #8 (permalink) |
Member: 232516 Status: Offline Thanks Meter: 2 | Can U Explain To Me How Did U Get Phone Booted Tell Me When U Do Connect Fast After That U Connect The Phone Or U Connect The Phone And After U Click Connect Fast Or What I Need The Way How To Star The Boot Please |
03-23-2007, 18:25 | #9 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | connect adapter to box then connect cable put 2.4 v click on fastboot then insert cable if phone dont boot in 2 seconds remove cable then insert again until phone is detected on software sometimes you have to insert many times the cable then enjoy... br |
03-24-2007, 00:46 | #10 (permalink) |
Member: 232516 Status: Offline Thanks Meter: 2 | CAN I CONTACT U IN PRIVATE PLEASE WYNASOFT IF YEAH ADD ME TO UR CONTACT IN MSN MINE IS [email protected] thanks |
Dits is looking for ressellers and distributers in latin america | DITS | DISTRIBUTER & RESELLER SECTION | 2 | 11-15-2009 04:14 |
Otuf C552 And Elle Adaptor For Sale In Morocco | elmehdi59 | Alcatel O.T.U.F | 4 | 04-29-2007 13:32 |
Error Connecting to Latin America C55x and ELLE | gsmmasters | Alcatel O.T.U.F | 2 | 03-18-2007 01:06 |
For Latin america *******r TDMA dct3 and DCT4 RPL | juanaldo | Main Sales Section | 0 | 06-29-2004 21:05 |
