Old 05-31-2007, 06:56   #1 (permalink)
Member: 431679
Thanks Meter: 19
6300 and 6233 Charger Not Supported
Anybody know a solution to a 'Charger Not Supported' fault for Nokia 6300 and 6233?
Any known faulty components in the charging network or do an Energy Management calibration?
Thanks for any help, hawsktf
The Following 11 Users Say Thank You to hawsktf For This Useful Post:
Old 05-31-2007, 07:17   #2 (permalink)
Member: 431679
Thanks Meter: 19
Flashing and energy management calibration did not work...
The Following 2 Users Say Thank You to hawsktf For This Useful Post:
Old 05-31-2007, 07:56   #3 (permalink)
Member: 25763
Thanks Meter: 18
Reflow TAHVO IC..if not solved change it.
The Following 2 Users Say Thank You to supremegsm For This Useful Post:
Old 06-01-2007, 07:25   #4 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
only change it, your problem may be solve and post the results.
The Following 24 Users Say Thank You to meo786pk For This Useful Post:
Old 06-02-2007, 14:22   #5 (permalink)
Member: 431679
Thanks Meter: 19
I successfully reflowed a 6233 TAHVO (it's a glued component so i had to be very careful), but for unsuccessful for the 6300
The Following User Says Thank You to hawsktf For This Useful Post:
Old 07-31-2007, 10:50   #6 (permalink)
oss001's Avatar
Member: 545608
Thanks Meter: 25
i also do but still same problem
The Following User Says Thank You to oss001 For This Useful Post:
Old 08-04-2007, 17:22   #7 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
me too i have two 6233 handsets pending for Charger Not Supported'
thank u
rockgsm
The Following 2 Users Say Thank You to rockgsm For This Useful Post:
Old 12-18-2007, 20:07   #8 (permalink)
mob-inter's Avatar
Member: 145732
Thanks Meter: 23
rehot and reflow TAHVO ic,, using flux and heatgun ,,,all will be well
The Following User Says Thank You to mob-inter For This Useful Post:
Old 12-19-2007, 04:17   #9 (permalink)
Member: 114531
Thanks Meter: 24
6300 Charger Not Supported Solution
Hi, mates. maybe this solution can help fix your mobile... then kindly post result.
this solution is tested by me.
br,
magnum
The Following 20 Users Say Thank You to magnum_GSM For This Useful Post:
Old 12-19-2007, 05:05   #10 (permalink)
Member: 597623
Thanks Meter: 6
great job thank for picture very much
The Following 2 Users Say Thank You to oil-za For This Useful Post:
Old 01-04-2008, 04:12   #11 (permalink)
Member: 607221
Thanks Meter: 13
please give me sum useful tips for nokia 6233 "charger not supported
The Following User Says Thank You to ajayparikh For This Useful Post:
Old 01-04-2008, 05:40   #12 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
bro check this picture,if not ok the final solution is at Retu ic,try to replace or changed it...good luck
The Following 20 Users Say Thank You to joni_yang For This Useful Post:
Old 02-06-2008, 00:33   #13 (permalink)
Member: 69935
Thanks Meter: 13
Talking
My lazy solution, for "Charger not supported" , Tested on 6234: Check battery, Connect charger and charge ower night on the morning all works perfect. 'Battery full' message on the screen make you happy.
Check if works for You
The Following User Says Thank You to fonelab For This Useful Post:
Old 02-06-2008, 15:42   #14 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
I am going to try with my 3110.
The Following 2 Users Say Thank You to YOUSSEF1975 For This Useful Post:
Old 02-07-2008, 06:16   #15 (permalink)
Member: 696868
Thanks Meter: 2
2630 chargernot supported
2630 charger not supported piz help me some tips give me
after make rpl 6233 charger not supported aloksoni Universalbox 5 02-05-2008 11:11
6233 Charger not Supported Any Solution ? .:RoMeO:. Nokia Hardware & Hardware Repair 3 12-18-2007 20:05
6233 charger not supported. rajaneesh Nokia Hardware & Hardware Repair 0 09-25-2007 10:56
6233 charger not supported, again... furija Nokia Hardware & Hardware Repair 0 03-19-2007 16:31
6233 Charger not supported geosan1638 Nokia Hardware & Hardware Repair 0 09-26-2006 21:53
Page generated in 0.23982 seconds with 10 queries
