FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam |
06-22-2007, 16:58 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Poland
Member: 112498 Status: Offline Thanks Meter: 33 | How to disable password protection on blackberry phones I've readed in tutorials section about method for disable password but I can't find on support files virus.bin and multilang.exe. What's wrong? em I going to wrong support site or I have got not fully acces? Please answer moderator. Regards, Emilkawa |
The Following User Says Thank You to emilkawa For This Useful Post: |
06-22-2007, 18:30 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Go http://www.gsm-hacking.eu/files/inde....EU%2FFLASHES/ Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
06-22-2007, 19:15 | #3 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Procedure [edit] Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. BlackBerry Software Site [edit] Step 2 Download the file policy.bin http://webpages.charter.net/john.cla...icy/policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). [edit] Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. [edit] Step 4 Close the Desktop Manager if it is open. [edit] Step 5 From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin [edit] Step 6 Open the Desktop Manager. [edit] Step 7 Connect the Device. now go to security tab you should see enable and disable password option added regards |
The Following 12 Users Say Thank You to GSM Deals For This Useful Post: |
11-28-2012, 22:44 | #12 (permalink) |
Insane Poster Join Date: Mar 2008 Location: tunis
Member: 716894 Status: Offline Thanks Meter: 18 | Procedure [edit] Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. BlackBerry Software Site [edit] Step 2 Download the file policy.bin http://webpages.charter.net/john.cla...icy/policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). [edit] Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. [edit] Step 4 Close the Desktop Manager if it is open. [edit] Step 5 From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin [edit] Step 6 Open the Desktop Manager. [edit] Step 7 Connect the test ok |
How to enter Unlock Code on BlackBerry Phones? [ONLY HERE] | ::.::RAMJAN::.:: | BlackBerry (RIM) | 51 | 10-01-2012 08:52 |
F-G Team & Product SUPPORT How to Disable PASSWORD on Blackberry phones jOIN HERE | ZoHaiB_(FoneGSM) | FuriousGold | 28 | 01-01-2009 08:14 |
BB8700g how to disable password..? | dirt_017 | BlackBerry (RIM) | 2 | 09-05-2008 07:24 |
How to disable password? | FMC_GSM | BlackBerry (RIM) | 5 | 08-14-2008 03:27 |
How to disable code protection in CX65 ? | gsm_unlock2 | S-Gold Based Phones | 4 | 11-29-2005 17:20 |
