Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 09-12-2007, 08:48   #1 (permalink)
Member: 565703
L6 no charge
hi all. i have L6 no charge, can help me any one,
Old 09-12-2007, 09:11   #2 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother,
L6 charge way, my fix
I don't guarantee that it will work for all charging problem but I fixed one that was not charging.
Symptom: No power up, power plugged in it says charging but finishes quickly, battery read only 1.6v. Universal charge detects no power.
Solution: Well I did not have a spare battery to swap with. Because the phone came alive charging when plugged in, suggests something to do with the battery. The phone was water damaged, I peeled off the battery plastic cover, the battery cell actually was fully charged after all the attempts and left overnight. The problem was caused by corrosion in the circuitry inside the battery. Clean it up, the voltage measured 4.06v, great! plug it in to phone and all is swell.
For people with invalid battery, try another battery 1st if it works then most likely your battery circuitry is shorting. A working battery measure 10kohms between -ve (pin4) and pin 3 (THERM) next to it; check that too.
Anyway check the circuit below, on L6 block diagram there is VR324 that goes to OWB (One Wire Bus), R910, R911 for current limiting look at the green charge color path. The battery is labeled 3.7v and charger is 5v; the zener is 6.93v just as an overvoltage protection.
Possible solution for other no charge & invalid battery, without the battery:
1) Check VR324 & VR325 not short by measuing Pin 4 to 1 & 2
2) Pin4 to Pin3 of battery = 10Kohms
3) Meassure at Pin 1 > +4v with USB charge & battery (need fly wire to battery) in if not check open R910 & R911, if they are OK
4) Check Q905 % Q906 FET at S & D if voltage is gating
Muhammad Afzal Meo
The Following User Says Thank You to meo786pk For This Useful Post:
Old 10-17-2007, 14:01   #3 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
L6 Problem Charge Solution
Finally i find, you must change the first fuse of the three little one at right who are parallel to the charge connector.
Begin with the number 2 on the picture.
Try and post your result !
Old 10-17-2007, 14:01   #4 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
The Following User Says Thank You to YOUSSEF1975 For This Useful Post:
Old 10-17-2007, 14:17   #5 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
Here is the picture !
Try and post your result: Thanks
The Following 2 Users Say Thank You to YOUSSEF1975 For This Useful Post:
Old 10-27-2007, 16:30   #6 (permalink)
Member: 524232
Thanks Meter: 7
hi,i need muster resetcode for motorola l6 plz.anybody help.
The Following User Says Thank You to pablos1 For This Useful Post:
Old 10-27-2007, 16:39   #7 (permalink)
Member: 524232
Thanks Meter: 7
motorola l6 earpiece not working,already i changed two earpiece but still same problem.plz help.
Old 11-19-2007, 12:20   #8 (permalink)
Member: 65657
Thanks Meter: 6
Thank's meo786pk
It works for me!
Finally I changed Q903 Q905 Q906 and Q904 and now it's charge!
Br tybee
Old 11-21-2007, 01:26   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any other circuit from which i take Q903 Q905 Q906 and Q904,bcoz i dont have other L6.
..::HUM::..
Old 01-26-2009, 08:41   #10 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
Your Problem Is 100% Solved here. Just Check this out.
Motorola L6 Not Charging Problem
Mobile Repairing Picture Help
Nokia Phones Repairing Section
Sonyericsson Phone Repairing Section
If you like the post please HIT THANKS BUTTON
The Following 7 Users Say Thank You to saqib_islam For This Useful Post:
Old 02-06-2009, 16:40   #11 (permalink)
Member: 373351
Thanks Meter: 9
I have motorola l6 but invalid battery and speaker problem.pls help me any body.
Motorola L6 not charging - shematic wanted chip_2000 Motorola Hardware Repair 12 01-26-2009 08:45
L6 can"t charge!! benson2727 Motorola Hardware Repair 10 04-30-2008 03:16
L6 don't charge gogomit Motorola Hardware Repair 4 07-13-2007 00:20
l6 no display and no service segun01 Motorola Hardware Repair 0 06-02-2007 21:01
L6 No Ring No Speacker Voice. stanner_austin Motorola Hardware Repair 3 08-08-2006 19:39
Page generated in 0.20399 seconds with 10 queries
