01-01-2008, 08:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Tutorial on converting DB2020 cid49/cid51 to cid 52 and unlock Note: Use DCU-60 cable. Procedure: 1. identify phone first by ticking "Identify" button. Code: v0.914014/UNI Card serial:000xxxxx Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35463701962686 CERT:N/A FLASH CID:51 COLOR:RED Model:K610i MAPP CXC article: R1GB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1GB001 Language Package:T_MOB_INT_A CDA article: CDA102497/8 CDA version: R12A Default article: cxc1250376 Default version: R1GB001 Extended LOCKED Operator: MULTIPLE RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:5 secs. 3. write this misc. files "DB2020_CID49_51_to_CID52" then tick "write script" * you can find this file in script folder Code: SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35463701962686 CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Will execute script now. Writing GDFS var 0001:084E len:010B Success Phone detached Elapsed:29 secs. Code: SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35463701962686 CERT:RED FLASH CID:52 COLOR:RED Model:K610i MAPP CXC article: R1GB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1GB001 Language Package:T_MOB_INT_A CDA article: CDA102497/8 CDA version: R12A Default article: cxc1250376 Default version: R1GB001 Extended LOCKED Operator: MULTIPLE RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Unlocking Procedure: 1. In "Settings" Tab tick "Complete phone after flash", "Unlock After Flash", "Use sever for csca unlock/flash", "Enable alternative security bypass" and empty user/password area. 2. Add flash files Main & fs (you need to put main & fs files if you don't have the same files that the phone is presently using, but if you have files then you can use the main file only.) 3. then click "Flash" button and follow all instructions and wait until it finished. Code: SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35463701962686 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:35463701962686 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK HOLD "C" BUTTON AND ATTACH AGAIN CID52 BYPASS PROCEDURE FINISHED ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: DB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok writing D:\Downloads\setool3 flash files\k610\cid52\R1JG001_1250540_CHINA_TH.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing D:\Downloads\setool3 flash files\k610\cid52\R1JG001_FS_APAC_TH_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:2740 Will flash 137 blocks... SSW loading returns:0 full sig complete. USERCODE RESET TO "0000" Searching... Firmware lock check determined. loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:989 secs. Happy unlocking....... Regards.......... |
01-24-2008, 03:22 | #8 (permalink) |
Junior Member Join Date: Sep 2006
Member: 360966 Status: Offline Thanks Meter: 1 | Phone Not Being Identified Hi! I am having a problem.when I changed the cid on a W850i to from 49 to 52.After that I detached the phone and turned it on with a simcard in as I saw in a video that you have to turn the phone on.Then I removed the simcard turned the phone off...and Now I am trying to follow the rest of the unlock procedure but when I connect the phone using dcu60 cable coming from SEbox it goes directly into data transfer mode and the setools wont identify it or do anything as the phone goes into data transfer mode straighaway.I have tried two other sony ericsson phone they are being identified fine.Please help me on how can I get the W850i identified. I am a new SETOOL user thats why dont know much ...please help |
i need that file which converts cid 49 and 50 and 51 to cid 52 | observer123 | SETool2 | 4 | 09-01-2009 18:05 |
Sucessfully Unlock Z610 Convert Cid 49 To Cid 52 | kisna | SETool2 | 1 | 11-23-2008 11:28 |
how to convert cid51 to cid 52 | shimul_777 | Cruiser Suite | 1 | 09-17-2008 15:22 |
CID 52?? And Unlocking a W580. | tofast4uall | Sony Ericsson | 1 | 04-02-2008 20:26 |
Problem With Update W880 Cid51 To Cid 52 | SEMEN | SETool2 | 12 | 02-24-2008 11:55 |
