CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes. |
02-15-2008, 23:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: ALGERIA, Tlemcen, Tounane Age: 37
Member: 135039 Status: Offline Thanks Meter: 1,486 | .:: [ READ RULES ] ::. - before you post - Updated 21.01.2016 - = Please Read the Rules Carefully = - ● Use only English language when you post. ● Do not post links to other forums with similar contents. ● Do not post links to serial number radio code calculators or databases, cracked software, patch or keygens, as they will be deleted immediately. ● When requesting a code you must include as much information as possible, eg serial numbers & model numbers, and if possible the electronic data from within the radio, refered to as a "dump" and the request must be posted in the Correct thread, incorrect posts will be deleted. (Please refer to "CarBase" if you are having problems identifying your radio) ● All replies about codes must be with only two numbers. Full codes only in private messages. ● Double posts will be deleted without notification, and double posting without an answer is only allowed after at least 24 hours. ● When your problem is solved, you must reply to the post and add "Solved" and push the "THANKS" button to the member who helped. ● Infractions will be given out if these rules are broken. Further infractions within a certain timescale will result in a temporary ban. ● Agressive behaviour will NOT be tolorated and may result in an infraction or ban. Changes of the rules, as well as adding new ones, are possible at anytime. Have fun and enjoy your stay ! Shooting Last edited by shooting@orange; 09-12-2016 at 19:35. Reason: Updated |
The Following 498 Users Say Thank You to spider-man For This Useful Post: |
Support F.A.Q. please read before you post | Raskal | BB5 Box by D.K. | 2 | 02-25-2009 17:18 |
Reminder* This is a Furious support Section. PLEASE READ BEFORE YOU POST ! | Fast Unlocker | FuriousGold | 0 | 12-13-2008 13:23 |
To KG-GSM look here before you post! | arvin_ado08 | The Market Feed Back | 1 | 07-05-2008 23:17 |
Before you post in UID section please read here first --Rules | .::Gsmdenis::. | UID - Box | 0 | 09-23-2007 21:49 |
