Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics
CAR Electronics however its a non GSM/Phone Related, but why not !! you can get here All Car Electronics Programming and Unlocking tools & Codes.
Old 02-17-2008, 11:12   #1 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
Thumbs up Car Base & Pinout's
HI
I open this thread , here we put all info about radio car :
Pinout's and RadioData
I start by CarRadioBase
Note : all post offtopic will be deleted
On-Line: http://codedradio.info/?i=bn
The Following 54 Users Say Thank You to spider-man For This Useful Post:
Old 02-18-2008, 19:20   #2 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Usefull website for pinouts: http://pinouts.ru/
Usefull website with radio data http://eserviceinfo.com/
The Following 6 Users Say Thank You to gsm9l For This Useful Post:
Old 02-21-2008, 06:00   #3 (permalink)
Member: 62866
Thanks Meter: 49
pinout
http://teletehnika.info/download.php...ref=0&subref=0
The Following 12 Users Say Thank You to stefan_162 For This Useful Post:
Old 02-21-2008, 14:11   #4 (permalink)
steva's Avatar
Member: 4772
Thanks Meter: 556
manuals for car radio:
http://codedradio.info/manuals/
regards
Last edited by spider-man; 02-21-2008 at 22:57. Reason: No dump , only data and schematic , thx :)
The Following 11 Users Say Thank You to steva For This Useful Post:
Old 02-26-2008, 12:49   #5 (permalink)
murat332's Avatar
Member: 238439
Thanks Meter: 608
Wink all carradio pin out
audi blau-pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins1.html
bmw clarion pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins2.html
grundıg honda pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins3.html
mitsubishi nissan pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins5.html
pioneer pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins6.html
subaru toyota pin out =
http://www.carsoft.ru/avtorepair/magn/pin/pins8.html
murat
The Following 10 Users Say Thank You to murat332 For This Useful Post:
Old 03-01-2008, 00:19   #6 (permalink)
Member: 132132
Thanks Meter: 4
pinout
Very good site (in polish) http://www.studio24.prv.pl/
The Following 4 Users Say Thank You to andastar For This Useful Post:
Old 09-05-2008, 11:36   #7 (permalink)
Member: 796252
Thanks Meter: 30
i use many times the ALLDATASHEET.COM , there u can find all semiconductores pinout
The Following 3 Users Say Thank You to portugal v3 For This Useful Post:
Old 09-29-2008, 22:33   #8 (permalink)
sixpack's Avatar
Member: 525282
Thanks Meter: 541
Originally Posted by murat332 View Post
all links are dead now
The Following 2 Users Say Thank You to sixpack For This Useful Post:
Old 10-03-2008, 08:35   #9 (permalink)
murat332's Avatar
Member: 238439
Thanks Meter: 608
Wink yes friend
http://teletehnika.info/articles.php?id=90
http://www.tehnomagazin.com/Auto-rad...O-konektor.htm
The Following 11 Users Say Thank You to murat332 For This Useful Post:
Old 10-08-2008, 14:24   #10 (permalink)
Member: 796252
Thanks Meter: 30
Opel display connecions
HI
im looking for addicional information of opel corsa/astra display connection
to test car 500 without car ( ive already got the display )
The Following User Says Thank You to portugal v3 For This Useful Post:
Old 10-13-2008, 19:27   #11 (permalink)
murat332's Avatar
Member: 238439
Thanks Meter: 608
Smile hi all (carradio how code in )
http://www.blueice-electronics.co.uk...elfhelp/codes/
murat
The Following 8 Users Say Thank You to murat332 For This Useful Post:
Old 10-15-2008, 14:43   #12 (permalink)
Member: 796252
Thanks Meter: 30
here have usefull opel connections
First You must know in which configuration this devices can work.
CAR200 Grundig 8/10
CAR300 Blaupunkt 8/10
CAR400 Philips 8/10
CDR500 Delco 8/10
CCR600 Philips 8/10
CAR2003 Blaupunkt 10/8
CAR2004 Philips 10/8
CDR2005 Delco lub VDO 10/8
Whole problem relies on correct adjusting number of sign of display and radio.
Displays:
5WK7 418 90 434 642 8 sign (Astra I, Corsa I, Tigra I)
5WK7 427 90 565 934 8 sign (Astra I, Corsa I)
5WK7 441 90 379 234 8 sign (Vectra i Omega before 1996)
5WK7 452 90 494 190 8/10 sign (Vectra i Omega after 1996)
5WK7 463 90 565 934 8/10 sign (Vectra i Omega after 1996)
5WK7 0007 00 91 33 265 8/10 (8+2) sign (Astra II, Corsa II, Agila)
Astra II, Corsa displays 10 sign
Wait for rest - conections.
After. Sory for my english. I still learning.
Regards.
[IMG]file:///C:/DOCUME~1/UTILZA~1/DEFINI~1/Temp/msohtml1/01/clip_image001.gif[/IMG]
Older radio
ISO "C" plug-in
1. SDA
2. SCL
3. GND
4. MRQ
New radio
[IMG]file:///C:/DOCUME~1/UTILZA~1/DEFINI~1/Temp/msohtml1/01/clip_image002.gif[/IMG]
"C" plug-in
5. SCL
8. MRQ
11. SDA
!!!Displays connections !!!
Standard: Astra I, Corsa I
[IMG]file:///C:/DOCUME~1/UTILZA~1/DEFINI~1/Temp/msohtml1/01/clip_image003.gif[/IMG]
1. +12V
2. NTC termistor
3. GND
4. NTC termistor
5. +12V after ignition switch
6. illumination
7. -
8. +12V after switch on the radio (remote antenna pin)
9. SCL
10.
MRQ
11. SDA
12. -
Omega and Vectra display
[IMG]file:///C:/DOCUME~1/UTILZA~1/DEFINI~1/Temp/msohtml1/01/clip_image004.gif[/IMG]
1,5,8 : +12V
2: GND
9: SCL
10: MRQ
11: SDA
Astra II, Corsa II, Zafira, Agila display
[IMG]file:///C:/DOCUME~1/UTILZA~1/DEFINI~1/Temp/msohtml1/01/clip_image005.gif[/IMG]
1.
2. radio/data
3. +12V
4. control unit
5. NTC termistor
6. GND
7. NTC termistor
8. DIAG
9. speed signal
10. SCL
11. SDA
12. MRQ
SCL Route clock
SDA Route data
MRQ Permission
remote antenna pin switching data/radio
DID - dual info display (clock and data/radio)
TID - triple info display (clock, data/radio, thermometer)
MID - multiple info display (clock, data/radio, thermometer, trip i check - board computer).
The Following 4 Users Say Thank You to portugal v3 For This Useful Post:
Old 10-15-2008, 18:22   #13 (permalink)
murat332's Avatar
Member: 238439
Thanks Meter: 608
Smile all carradio pin out
http://www.byminsk.com/others.htm
and manuel catalogs ( O BLAUPUNKT )
http://www.blaupunkt.com/us/downloads_1.asp
murat
The Following 4 Users Say Thank You to murat332 For This Useful Post:
Old 10-18-2008, 09:37   #14 (permalink)
murat332's Avatar
Member: 238439
Thanks Meter: 608
Smile IC / Datasheets
http://www.alldatasheet.com/
http://www.datasheetcatalog.com/
http://www.datasheetarchive.com/
http://www.datasheetdir.com/
The Following 5 Users Say Thank You to murat332 For This Useful Post:
Old 12-10-2008, 22:34   #15 (permalink)
Member: 394348
Thanks Meter: 21
http://carstereohelp.net/wireharness_Mitsubishi3.htm
The Following 5 Users Say Thank You to Synkrotronic For This Useful Post:
Car Bluetooth & Mirror with LCD - WD0608 IPMART ipmart WebShop 0 03-24-2009 07:40
Car Charger & FM Transmitter for iPod/iPhone IPMART ipmart WebShop 0 03-17-2009 13:20
Car Bracket & Charger for Dopod P860 Phone - Original IPMART ipmart WebShop 0 03-01-2009 21:00
Need new car base Velko CAR Electronics 0 05-27-2007 08:55
Information about Car Aduio & Video metronetGSM CAR Electronics 0 05-22-2007 12:47
Page generated in 0.32054 seconds with 10 queries
