Old 04-10-2008, 06:47   #1 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
3110 C Restart Good Result
Any Friends U Have 3110c Restart
I M Solv This Prob..
No More Idea Only One
Write Cnt File Then Full Facktory Defult
Good Result I Tested More 3110 C Phone
.....good Luck.....
The Following 8 Users Say Thank You to Parminder Singh For This Useful Post:
Old 04-24-2008, 11:48   #2 (permalink)
Registered User
Member: 492884
Thanks Meter: 143
thanks sir very good idea i have test many set thanks very much
Old 04-25-2008, 16:22   #3 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
good info .....
digitized
Old 04-25-2008, 16:27   #4 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
flash with v6.01 or v6.02 problem solved tested 1000%
Old 04-25-2008, 16:31   #5 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Oi
the is small problem too when u open galory restart there is any solution for that?
Old 04-25-2008, 17:52   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
.....good Luck.....
Yes dear it is possible.
Because CNT file content only Galary data.
In some case Galary data Corupted then result is phone is restart.
Old 05-14-2008, 09:20   #7 (permalink)
Member: 161008
Thanks Meter: 3
wat abt when using speakerphone it auto restart ,i flash to new version also same
Old 05-14-2008, 10:13   #8 (permalink)
Member: 606473
Thanks Meter: 5
3110c restart solution:
- No need RPL !!!
- No need to flash your phone !!
For solve this problem just use following steps : (Only the order)
1- Remove sim card .
2- Remove MMc and format it by your PC.
3- Open phone without sim and without MMc .
4- Reset phone . ( go to settings >> ...) .
5- Put MMC and do formating from phone , Then do reset again to phone .
6- Put sim card to phone and power it on , Then do reset again .
7- Now phone with MMC and Sim ( Put USB to phone and back all data to MMc ).
And now phone work good 100 % , tested by me with 10 pc.
The Following User Says Thank You to milenko_pin For This Useful Post:
Old 05-14-2008, 11:02   #9 (permalink)
Member: 7220
Thanks Meter: 1,592
- No need RPL !!!
one simple solution.
Just attach phone to phoenix and format all drives. Just one step will do.
Best Regards
Alan Tan
The Following User Says Thank You to xpmobile For This Useful Post:
Old 05-15-2008, 16:45   #10 (permalink)
Member: 767451
Thanks Meter: 178
i don have this v6.01 or v6.02 file for rm237 pls help me thanx plz pls any user you have this version ,.than kyou
Old 05-15-2008, 16:46   #11 (permalink)
Member: 767451
Thanks Meter: 178
pls pls send mcu, ppm + cnt only for 3110c thanx
Old 05-15-2008, 16:48   #12 (permalink)
Member: 767451
Thanks Meter: 178
or where the free site may i download this file v6.01 or v6.02 rm 237 thanx
Old 05-22-2008, 11:20   #13 (permalink)
Member: 379065
Thanks Meter: 1
3110 restart
hey
flash with new version 6.*
solved
Old 06-26-2008, 13:55   #14 (permalink)
Member: 542743
Thanks Meter: 81
3110c Restart Solution:
- No Need Rpl !!!
- No Need To Flash Your Phone !!
For Solve This Problem Just Use Following Steps : (only The Order)
1- Remove Sim Card .
2- Remove Mmc And Format It By Your Pc.
3- Open Phone Without Sim And Without Mmc .
4- Reset Phone . ( Go To Settings >> ...) .
5- Put Mmc And Do Formating From Phone , Then Do Reset Again To Phone .
6- Put Sim Card To Phone And Power It On , Then Do Reset Again .
7- Now Phone With Mmc And Sim ( Put Usb To Phone And Back All Data To Mmc ).
And Now Phone Work Good 100 % , Tested By Me With 10 Pc.
please Let Me Tell The Procedure Formatting By Pc
I Only Have One Ufs-5 Box With Me
Thanks In Advance
Old 08-04-2008, 16:30   #15 (permalink)
Member: 308142
Thanks Meter: 20
- No need RPL !!!
thanx sir its great it works for me
The Following User Says Thank You to aakif_nab For This Useful Post:
3110,3110,6300 restart pro after flash.......100% ok tested by mr many time mmmfaruk Nokia Hardware & Hardware Repair 2 01-26-2010 12:11
3110 c restart with memory card munnachikku Nokia Base Band 5 ( BB-5 ) 21 11-01-2008 19:09
search is not giving good results alru111 Board, Server and Login Problems/Support 0 12-16-2005 15:34
change imei 720x temporaly good results sparkgsm Motorola P2k 5 02-18-2004 02:01
Page generated in 0.23435 seconds with 9 queries
