FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam |
04-11-2008, 21:42 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | 11/04/08 Full support added for ZTE A35 and ZTE A61 ZTE A35, ZTE A61 [X] UNLOCK [X] WRITE FLASH [X] READ FLASH [X] READ EEPROM [X] WRITE EEPROM HOW TO USE (READ BEFORE YOU CRY ETC.) 1. READ EEPROM, WRITE EEPROM ALLWAYS WRITE EEPROM OR BACKUPS OF EEPROM CREATED BY SOFT TO SAME PHONE. NEVER WRITE OTHER EEPROM TO OTHER PHONE BECAUSE YOU WILL TOTALLY BRICK YOUR HANDSET. WRITE EEPROM BACK CREATED BY BACKUP ONLY IF SOMEHOW UNLOCK PROCESS FAILED SOMEHOW. ELSE SIMPLY DONT DO IT ! 2. UNLOCK. HOW IS DONE !? - SELECT UNLOCK OPERATION FROM JOBS - *#06# AND TYPE IMEI YOU SEE ON IMEI BOX YOU SEE ON BOX - PRESS DO JOB - SELECT _FW FILE WITH DESIRED VERSION/LANGUAGES THAT MATCHED YOUR NETWORK YOUR PHONE IS LOCKED ON. - WAIT PROCESS TO FINISH (WILL TAKE BEETWEN 1 AND 2 MINUTES AT FULL SPEED) 3. WRITE FLASH - IS USUALLY USED TO CHANGE LANGUAGES/FW. REPAIR SOME MISC PBS. IF YOUR PHONE ISNT UNLOCKED BY CODE THEN THIS WILL RELOCK YOUR PHONE SO IN CASE UR PHONE IS LOCKED AND YOU PLAN CHANGE LANGUAGE, REPAIR THEN USE UNLOCK. 4. READ FLASH - USE THIS TO READ YOUR HANDSET FW. IS NEEDED FOR US IN ORDER TO AD NEW FWS TO OUR COLLECTION. FWS ADDED ON SUPPORT: ./A61 A61_CELTEL-P108A11B01-EnFr-01_FW.zip ./A35 AREEBA-P108A5B01-EnFr-GN01_FW.zip CELTEL-P108A5B01-EnFr-01_FW.zip CLARO-P108A7(Z)B01-EnEs-PE02_FW.zip NOTE: USE VODAFONE MODULE AND USE PROPER FIRMWARE DEPENDING NETWORK YOUR PHONE IS LOCKED ON. IF NO FIRMWARE AVAILABLE FOR NETWORK OF YOU PHONE PLEASE READ FLASH AND SEND US. Br |
17/04/08 LG KE520/KE590/KM500/KP100/KP105/KP106 Full Support Added ! | .:hack3r2k:. | FuriousGold | 110 | 06-15-2009 19:48 |
10/07/08 Full Support Added For Modelabs Airness Slide99 ! | GhosT2RocK | FuriousGold | 1 | 07-12-2008 00:49 |
10/07/08 Full Support Added For Modelabs Airness Slide99 ! | sharaz191 | Service Products News & Updates | 0 | 07-10-2008 15:53 |
NEW UPDATE Post 28/06/08 Zte Z39 Full Support Added ! | skyulock | FuriousGold | 2 | 06-28-2008 17:32 |
11/04/08 : ET-BoX v1.61 Released - Added Bleu 551x & Improved Format for MTK | nonu_don | ET-BoX | 23 | 04-18-2008 10:04 |
