Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Mark Forums Read |
04-21-2008, 05:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | LG KE850 unlock problem Please help after unlocking phone, when power on, it shows "Insert Right Sim Card" Could it be IMEI / eeprom problem as the value does not match the IMEI at the back. However, the phone was working before unlock. Here is the log. COM9 [VCP0] selected Device: LG KE850 Checking data, wait... Action: unlock Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080421-125414.B1E.bin reading [eeprom-sta2]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080421-125416.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080421-125418.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080421-125420.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01D5 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 20 sec |
04-22-2008, 02:26 | #4 (permalink) |
Member: 1133 Status: Offline Thanks Meter: 38 | Hi, The IMEI has been restored. Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KE850P40-852-V10h-***-XX MAY 17 2007+0 original imei: 3534260135****600 new imei: 3534260135**** Done Finished |
04-26-2008, 12:35 | #11 (permalink) |
Crazy Poster Join Date: Nov 2005 Age: 45
Member: 204317 Status: Offline Thanks Meter: 0 | hello i have the same problem with ke850. after flashing it with KE850CP40-7-V10i-***-XX_JAN-19-2008_firmware.B1M KE850CP40-7-V10i-***-XX_JAN-19-2008_file_system.B1S i get this message "Insert Sim Card" i have tried to write eeprom but still no luck for me i have tried to flash with vigys also but its the same problem. is there any good solution for this problem? |
04-26-2008, 15:52 | #12 (permalink) | |
Is it problem with unlock or another problem ? | |
04-28-2008, 10:52 | #13 (permalink) |
Member: 204317 Status: Offline Thanks Meter: 0 | after flashing the phone i get this message "Insert Sim Card" although the sim card is inside. It`s not a hardware problem because the phone was working before i have flashed it. I`ve tried to flash it with different flash files but i havent been succesfull. i`ve tried to flash the eeprom too but again i was not succesfull. Finaly i have flashed it with VIGYS box and everything was fine I wonder what is the problem with Infinity box? |
04-28-2008, 13:45 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @talat There is no problem with Infinity-Box, the only problem is that we did not had that flash file that was suitable for your phone. We will be glad to get more flash backup files so we will be able to upload it in support area for all users: [email protected] |
05-05-2008, 10:55 | #15 (permalink) |
Member: 1133 Status: Offline Thanks Meter: 38 | @ Product Supporter. Can you tell me why it is very difficult to re-write back IMEI? Sometimes can write, but when come to verify, it says errror. At other times, i get this error report Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished I am using Original USB cable (no modifications) plugged to an adaptor to Infiniti box. Thanks |
Thread Tools | |
Display Modes | |
lg ke850 sim problem | MOBO12DZ | LG | 6 | 11-06-2014 13:47 |
LG KE850 unlock | RodolfoR | PolarBox 3 | 0 | 06-10-2008 12:57 |
ke850 unlock problem | alex1205 | FuriousGold | 3 | 11-21-2007 13:07 |
KE850 Unlock problem after flash | jodge | VygisToolbox | 12 | 09-05-2007 06:14 |
KE850 unlock problem | roberts | FuriousGold | 2 | 08-22-2007 13:29 |
