Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 04-23-2008, 20:25   #1 (permalink)
SiLver GSM's Avatar
Member: 210304
Sonork: 100.1573283
Thanks Meter: 1,455
::Here How To Work With Spider-Man Box ::
Here Only You Can Find How To Use Spider-Man Box
1-The Connect button which use for connect box with program
If connection Is Good this button will be Disconnect
2-Select Comport which u can use
3-Select Baundrate For Comport
4-Used For Make Conaction With Phone ((Boot The Phone))
5-Used For Make Order To write selected Flash Files on Nor Flash Or Nand Flash
6-Used For Make Order To Read Flash Files Form Phone And Request for where u want to save backup flash files
7- Used For Make Format Opration and if u check to Manual Format Default this option is required to Make Manual Set For Foramt Area
8-Used For Unlock Phones ((open all network locks ))
9-Used For Find Pinout For Phone and give us Correct Tx And RX Pins
(( We Can choose From 2 Options 1St, 1 Cpu Phones - 2Nd, 2Cpu Phones ))
10- We Can Used This Option to Defind Pinouts and Save Our Correct pinouts Searching
11-This Opation allowed us To Convert Flash Files which Had Bin Extension
To Bif Extension
12-Used For Abort Any Working Opartion
13-Used TO Know Any New Updates In Support Area
14-This Bar allowed us To Change between Phone Cpu which We Have
Like MTK And SPreadtrum .......
15- here We Can Open Nor Flash which we Want To Flah it to phone
16- here we also can choose where we want to save reading flash files
17- Same as last oprations ((15-16)) But Here For Nor Flah Area
18- Used For Rebuild Iemi for Phone
19- Used For Make Full Factory Defaults
20- The Area For Read all Info About SW and Flash File Details
Hope This Info Help U TO Work With This Great Tool
The Following 87 Users Say Thank You to SiLver GSM For This Useful Post:
Old 04-23-2008, 20:40   #2 (permalink)
SiLver GSM's Avatar
Member: 210304
Sonork: 100.1573283
Thanks Meter: 1,455
Spiderman Read&Flash
connect box to computer .connect phone to box and cable
YOU Must choose MTK CPU.click”Search Phone”.when found cable pinout
1. Read flash
* click”Save” Choose save file folder and save name
* click"Read” after press” power on”button in the phone Bootloader phone
Reading........
2. Flash phone.
* Click”Open” choose flash the phone flash file
* Click”Flash” after press” power on”button in the phone Bootloader phone
NOW Flash complete
BR,
SiLverGSM
The Following 83 Users Say Thank You to SiLver GSM For This Useful Post:
Old 04-24-2008, 07:44   #3 (permalink)
Member: 695023
Thanks Meter: 53
great moved man...
keep it up...
The Following 8 Users Say Thank You to ACID_ICED For This Useful Post:
Old 04-24-2008, 08:41   #4 (permalink)
Registered User
Member: 557525
Thanks Meter: 67
yes fırst pın outo good work good fınd hehe spıderman best box
The Following 6 Users Say Thank You to RaSkAl01 For This Useful Post:
Old 04-24-2008, 08:48   #5 (permalink)
Member: 322417
Thanks Meter: 940
thks for explain............................
The Following 4 Users Say Thank You to Formingus For This Useful Post:
Old 04-26-2008, 22:02   #6 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
Cool
Great .. very nice mr's
GsmJoman
Tc
The Following 4 Users Say Thank You to saiftc2 For This Useful Post:
Old 04-26-2008, 22:32   #7 (permalink)
Member: 674037
Sonork: 100.1577050
Thanks Meter: 13
Great Mr Silver
Good Luck
B'R
Minihack
The Following 4 Users Say Thank You to minihack For This Useful Post:
Old 04-27-2008, 18:39   #8 (permalink)
Member: 633957
Thanks Meter: 4
great work ...
m.r :silver
The Following 3 Users Say Thank You to ZABIKE For This Useful Post:
Old 04-27-2008, 23:38   #9 (permalink)
Member: 143156
Thanks Meter: 95
thank u mr. silver very good
The Following 3 Users Say Thank You to gsm4sp For This Useful Post:
Old 04-29-2008, 08:48   #10 (permalink)
.::ricky rayya::.'s Avatar
Member: 254397
Thanks Meter: 224
how i can format spreadtrum cpu
very good sir but how i can format & read ,write flash for spreadtrum cpu
..::RICKY RAYYA::..
The Following 9 Users Say Thank You to .::ricky rayya::. For This Useful Post:
Old 04-29-2008, 17:02   #11 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 778
very nice mr//SiLverGSM
MR / KEMO
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post:
Old 04-29-2008, 17:47   #12 (permalink)
-KimoAlex-'s Avatar
Member: 80172
Sonork: 100.1575306
Thanks Meter: 82
Great work from my dear brother
Best Regards...
Your Borther
KimoAlex
The Following 2 Users Say Thank You to -KimoAlex- For This Useful Post:
Old 04-29-2008, 17:52   #13 (permalink)
SiLver GSM's Avatar
Member: 210304
Sonork: 100.1573283
Thanks Meter: 1,455
..::RICKY RAYYA::..
We working for this now
just few steps and it will be ready
Br,
SiLverGSM
The Following 7 Users Say Thank You to SiLver GSM For This Useful Post:
Old 04-29-2008, 20:32   #14 (permalink)
karemriko's Avatar
Member: 150857
Thanks Meter: 31
THE BEST OF ALL
The Following 3 Users Say Thank You to karemriko For This Useful Post:
Old 04-29-2008, 20:47   #15 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
and what r u doing for infeneon cpu, pls give fast update.... now badly need the support of speadtrum and infeneon cpu to unlock , flash read/ write ....................
The Following 3 Users Say Thank You to sharmin For This Useful Post:
How to calibrate china phone with spider man box tamungas Chinese Models & Cloned Phones 1 01-11-2012 21:03
LG KG195 unlock sucess with spider man box ..::My3gtech::.. Chinese Models & Cloned Phones 8 07-25-2011 09:15
karbonn k444 flashing with spider man box? ramcellular SpiderMan 3 08-02-2010 09:50
How to work with 2-3 boxes simultaneously! ProGsm2K7 FuriousGold 13 03-02-2010 22:41
I not know how to work with sagdd box . mileta5 SAGEM JTAG UNLOCKER 8 02-20-2009 11:49
Page generated in 0.23015 seconds with 10 queries
