Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
05-17-2008, 02:04 | #1 (permalink) |
Banned Join Date: May 2008
Member: 769112 Status: Offline Thanks Meter: 163 | TomTom With Internal GPS Support v6.02 S60v3 SymbianOS9.1 FULL WORKING [17MAY UPDATE] OverView : Easy to use: The simple installation and intuitive user menu gives you the perfect navigation experience.Clear and accurate spoken and visual instructions: Easy to follow route instructions and crystal clear 2D or 3D maps lead you from door-to-door whether you travel by car, by bike or on foot. Easy call handling: Never miss a call or SMS message while navigating through on-screen instructions.Navigate direct to contacts stored in your address book Installation Notes : 1) Install 1.bt.sisx. Run it. It should say "Device added" At this point you can also uninstall it - it is no longer needed. 2) Install 2.GPSd.jar. Run this prior to starting TomTom 3) Install 3.tomtom.sisx 4) Copy the TomTom folder from the 0.Copy.To.MEMCARD.Root.rar to the root of your memory card. 5) Run TomTom. Choose Yes when it asks you to switch on bluetooth. Go to Change preferences, Show GPS status, Configure, Other Bluetooth GPS receiver, and select the BiNPDA GPS. * You need to change the preferences every time you start tomtom. It won't remember that you were using the internal GPS* * If you need to switch from internal, to an "external" receiver, you may need to click on "tomtom receiver", and then "other receiver" to get the list of devices again. Enjoy this Release.. Many Thanks to BiNPDA Team. DOWNLOAD |
The Following 46 Users Say Thank You to kawungalew For This Useful Post: |
05-17-2008, 04:43 | #3 (permalink) |
Junior Member Join Date: Nov 2007
Member: 628437 Status: Offline Thanks Meter: 1 | brilliant got tomtom working using internal gps on nokia n95,the question i want to ask is when you run the gpsd file which you have to do everytime before starting tom tom it asks if its ok to get poisitioning and send and recieve data which you have to say yes to otherwise tom tom will not use internal gps,do you get charged for using this servive..i.e will it show as data usage via internet? or will this be completly free?...but i can confirm it is all working perfectly and is fast to get gps fix |
The Following User Says Thank You to elrazor For This Useful Post: |
05-17-2008, 09:26 | #7 (permalink) |
Member: 769112 Status: Offline Thanks Meter: 163 | 1) Copy bt.sisx, GPSd.jar, tomtom.sisx and the "TomTom" directory from the Copy.To.MEMCARD.Root.rar file to the root of the memory card 2) Install bt.sisx 3) Install tomtom.sisx 4) Run bt from the applications menu (this apparently can then be uninstalled) 5) Run GPSd from the applications menu 6) Run TomTom from the applications menu Configure TomTom: 1) Set preferences (such as distance/time format) 2) Choose "Other GPS Device" from the GPS setup menu 3) Allow TomTom to turn on Bluetooth 4) Choose BiNPDA from the device list That's it! The maps MUST be in the root (along side the TomTom folder from the downloads). more info ask here : http://*******.com/yt36w3 |
The Following 8 Users Say Thank You to kawungalew For This Useful Post: |
05-17-2008, 12:30 | #8 (permalink) |
Junior Member Join Date: Apr 2008
Member: 754820 Status: Offline Thanks Meter: 0 | Woo-Hooo!!! This is excellent!!! Working on N95 8gb. I really dont want to sound negative on this achievment, but will it be updated to allow it to remember that its using the internal GPS? Also, is this GPS or aGPS? Once again, this is excellent. |
05-17-2008, 13:13 | #9 (permalink) | ||
Member: 769112 Status: Offline Thanks Meter: 163 | Quote:
great to know that its working | ||
05-17-2008, 17:01 | #13 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 650415 Status: Offline Thanks Meter: 0 | can anyone tell me what my maps must be named, as tomtom says no maps found and i have uk map on root of card. many thanks some one must no as many people have this working. many thanks |
TomTom With Internal GPS Support v6.02 S60v3 SymbianOS9.1 Cracked-BiNPDA | Ozling | Nokia Multimedia | 2 | 10-06-2009 20:50 |
TomTom With Internal GPS Support v6.02 S60v3 SymbianOS9.1 Cr@cked-BiNPDA | chotadon | Nokia Multimedia | 30 | 09-06-2009 03:05 |
