Old 05-20-2008, 21:45   #1 (permalink)
tostefo's Avatar
Member: 77941
Thanks Meter: 120
N81 camera problem solution
last days i have 4 different nokia n81 and n81 8gb with same error - when try to access camera "feature not supported" so i start "DIG" them but withaut success, at last i found it - problem is on R2500 which is between sysclk and stv0984n /D2500 on SVC/ original value is 15 ohm but you can bypass it with any fuse or wire
WBR
The Following 25 Users Say Thank You to tostefo For This Useful Post:
Old 06-05-2008, 19:49   #2 (permalink)
rajtelecom's Avatar
Member: 446363
Sonork: 1577571:rajtelecom
Thanks Meter: 216
thanks my firend
but not working any other solutions?
The Following 3 Users Say Thank You to rajtelecom For This Useful Post:
Old 11-11-2008, 08:19   #3 (permalink)
Member: 74220
Thanks Meter: 5
camera n81
WBR
can you show me where is R2500?
The Following 2 Users Say Thank You to jordi For This Useful Post:
Old 11-11-2008, 08:24   #4 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
thanks for sharing SIR TOSTEFO... keep posting.....
The Following User Says Thank You to howell For This Useful Post:
Old 12-24-2008, 12:21   #5 (permalink)
Member: 275324
Thanks Meter: 35
thankssssssssssssssssssssssssssssssssssss,,,,,,,
The Following User Says Thank You to mobilezone_mzia For This Useful Post:
Old 01-02-2009, 17:37   #6 (permalink)
Member: 770405
Thanks Meter: 3
thanks you are good man
The Following User Says Thank You to yj7469 For This Useful Post:
Old 01-08-2009, 08:01   #7 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 67
any one tested? thx for solution,i tested and not work for me
The Following User Says Thank You to .::Indian::. For This Useful Post:
Old 01-17-2009, 13:08   #8 (permalink)
srv
Member: 123943
Thanks Meter: 24
tri this and post result
The Following 13 Users Say Thank You to srv For This Useful Post:
Old 01-17-2009, 13:10   #9 (permalink)
Member: 894862
Thanks Meter: 21
just replaced only the flex cable, you must use original flex work it properly
Old 01-23-2009, 08:44   #10 (permalink)
Member: 82886
Sonork: adyblana
Thanks Meter: 8
camera: feature not suported flex cable is bad. 1000% tested
The Following User Says Thank You to AdyBlana For This Useful Post:
Old 01-30-2009, 15:58   #11 (permalink)
Member: 959813
Thanks Meter: 1
hiiiii i need help
how can i do it??
also i have this problem" feature not supporestd!!
what is the flex caable?????
Old 01-30-2009, 16:00   #12 (permalink)
Member: 959813
Thanks Meter: 1
WBR
hii i still have this problem ,, ireally need ur help
thnx
Old 01-30-2009, 16:12   #13 (permalink)
Member: 721923
Thanks Meter: 4
camera : fiture not support?
The Following 2 Users Say Thank You to purqon For This Useful Post:
Old 01-30-2009, 17:36   #14 (permalink)
Member: 959813
Thanks Meter: 1
yes this hapens to me
The Following User Says Thank You to cherly For This Useful Post:
Old 01-30-2009, 19:04   #15 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 49
Change N2531 worked 4 me
The Following 2 Users Say Thank You to Don_R For This Useful Post:
N81 camera problem success repair... watari31 Nokia Hardware & Hardware Repair 3 12-30-2010 12:10
Nokia n81 camera problem transpirit Nokia Base Band 5 ( BB-5 ) 4 12-08-2009 05:06
nokia n81 keypad problem solution pls ??? roney_nexus Nokia Hardware & Hardware Repair 3 05-15-2009 04:50
n81 camera problem shami61 Nokia Hardware & Hardware Repair 2 02-08-2009 18:33
!!!E900 Camera problem Solution Here !!! SiRoYa UST Pro II 24 02-23-2007 02:55
Page generated in 0.26693 seconds with 10 queries
